0 Members and 1 Guest are viewing this topic. Read 5662 times.
Yes, the ol' stick a pair of rolled up socks in the port trick, and variations of same. Sticking a smaller cardboard tube inside of the port tube, sometimes also a bit longer, can tame a boomy system. All of these things alter the tuning frequency of the port and can improve systems designed to have a bass hump, which I think might be the case with the JBL Ti 120. So your fix of using a foam plug should be right on point. Did you narrow the port with a cylindrical plug, e.g. reduce the diameter of the port, or did you restrict the airflow with a full plug?
Hello. I was just wondering if anyone has experimented with their reflex ports to better control bass in a room. For 24 years I have braced and mass loaded my JBL Ti 120 speakers. They are on concrete stands. They are driven by a great Bryston 4bst amp through 6 ft. of Audioquest CV4 wire. The last thing I have done is to narrow the ports with a foam plug . Everything has suddenly snapped place. Mids are clearer and the bass is tighter and focused. Anyway , thanks for reading this and I hope my efforts may help someone ................
Chuffing?
So we've covered port size a bit, but I am still curious about the effects of port tubes. Any rules of thumb for tube length. Advantages or disadvantages of flared tubes vs. cylinder shaped ones?
