875HT
0 Members and 1 Guest are viewing this topic. Read 4078 times.
alexone
875HT
« on: 28 Oct 2011, 08:03 pm »
James,
the 875HT amps seem to have a different styled frontplate compared to the C-Series (SST²) amps. somehow the 875's front and the SP2's front look the same... :scratch:?!?
correct?
al.
  • The Demo is Everything!
    • http://www.bryston.com
Re: 875HT
« Reply #1 on: 28 Oct 2011, 08:09 pm »
James,
correct?
al.
Hi al,
Not sure I understand - post the pictures.
james
alexone
Re: 875HT
« Reply #2 on: 28 Oct 2011, 08:21 pm »
...this is from the current website:
http://bryston.com/875ht_m.html
http://bryston.com/sp2_m.html
and this is the 2B SST² for example...
http://bryston.com/2bsst_m.html
al.
alexone
Re: 875HT
« Reply #3 on: 28 Oct 2011, 08:25 pm »
James,
there is a review from "The Audio Critic" about the 875 and they say that Bryston doesn't specify an FCC rating for this amp (driven into 4 ohms).
what is a FCC rating?
al.
Re: 875HT
« Reply #4 on: 28 Oct 2011, 08:32 pm »
al.
Ones a 19 inch rackmount pro style faceplate and the other a 17 inch consumer style.
james
alexone
Re: 875HT
« Reply #5 on: 28 Oct 2011, 08:34 pm »
james
ok. so the 17" C-Series version of the 875 looks like the rest of the 17" C-Series SST² amps?
al.
Re: 875HT
« Reply #6 on: 28 Oct 2011, 08:39 pm »
al.
Correct but because we usually sell the 875 into commerial zone systems I do not think we have ever sold a c-Series faceplate version.
james
alexone
Re: 875HT
« Reply #7 on: 28 Oct 2011, 08:49 pm »
but i guess that a faceplate change can be done if needed by the customer. 8)
al.
Re: 875HT
« Reply #8 on: 28 Oct 2011, 10:50 pm »
al.
Yes but it is not an easy job with all the LEDs etc. that need to be lined up.
james
Teyry
Re: 875HT
« Reply #9 on: 28 Oct 2011, 11:31 pm »
I wish Bryston would issue a 575HT or 675 HT. 75 watts per channel would be more than adequate for my center and surround speakers set @ 80hz crossover. Add to it a 4B-SST2 for my L/R and you have a perfect 7 channel amp system.
A 5 or 6 channel version would save me some cash and keep me from looking at less expensive  alternatives for my surround upgrade.
I had a Classe' CAV-75 driving my center and surrounds about 10 years ago and I loved it, never felt like I needed more power. I would be very interested in a 5 or 6 channel version of the Bryston 875HT.
alexone
Re: 875HT
« Reply #10 on: 29 Oct 2011, 08:34 am »
james
...so that would mean additional costs due to the complexity of the job??
al.
Re: 875HT
« Reply #11 on: 29 Oct 2011, 11:03 am »
al.
Not at the factory level but do not try this at home.
alexone
Re: 875HT
« Reply #12 on: 29 Oct 2011, 11:07 am »
...I'm not an engineer so i would never ever even try to manipulate any amplifier for any matter :nono:
al.
alexone
Re: 875HT
« Reply #13 on: 17 Nov 2011, 04:00 am »
James,
are there any topless pictures of the 875HT ? i searched the web and couldn't find much...
thanx,
al.
alexone
Re: 875HT
« Reply #14 on: 21 Nov 2011, 04:51 am »
James,
since the 875 has no gain switch i'd have to use the level control on the back of the amp. i guess the lowest relates to 23db and the highest relates to 29db?
al.
Re: 875HT
« Reply #15 on: 21 Nov 2011, 10:49 am »
James,
al.
Hi Al
It has a range of 29 to13dB
Jam
