Industry Circles
Bryston Limited
14B ST Questions
14B ST Questions
0 Members and 1 Guest are viewing this topic. Read 1855 times.
clayeton
14B ST Questions
28 Oct 2011, 03:39 pm »
I'm wondering if someone can help me with what the relevant differences are between the 14B ST and 14B SST? I'm looking at buying a 14B ST to replace my 4B ST and wondering if it's better to wait and find a 14B SST.
Thanks for your help.
Clayeton
Habs Fan
Re: 14B ST Questions
29 Oct 2011, 12:34 am »
I believe the difference is approx 100 additional watts of output for the SST(600 vs 500 for the ST)due to higher tranformer secondary voltages.
Phil A
Reply #2 on:
29 Oct 2011, 12:46 am »
The later 14BSTs might be SSTs from memory (could be wrong). Probably an old thread on serial nos. I'm sure James Tanner will chime in.
Phil A
Reply #3 on:
29 Oct 2011, 12:47 am »
PS - Welcome to the forum
Phil A
Reply #4 on:
29 Oct 2011, 12:53 am »
Here's one old thread -
http://www.audiocircle.com/index.php?topic=26165.0;imode
mclsound
Reply #5 on:
29 Oct 2011, 12:18 pm »
I believe the factory final spec sheet that comes with their amps is
14bsst-633w/ch
14bst600w/ch
so although they are rated at 100w difference,the actual performance is only around 35w
They are the same amp as the SST,so is a 6bst
Facilitator
The Demo is Everything!
Reply #6 on:
29 Oct 2011, 12:51 pm »
Hi Folks,
The original 14B ST was the first of the SST's but it was replaced with the 14B SST2 which has the new Torus style transformers. So it is not just a power difference between the two.
james
Industry Circles
Bryston Limited
14B ST Questions
