0 Members and 1 Guest are viewing this topic. Read 41826 times.
I'd like to address this issue of the "impossible" room. If a designer shows equipment, and it sounds like crap, then it sounds like crap. No excuses about the room, the thin Denver air, ambient noise, break in, etc. For dealers to display their equipment under poor conditions is either arrogance, poor planning, or laziness. In case I didn't piss off enough people, let me repeat arrogant, poor planning, or lazy. For those that really want their stuff to shine, no effort is too great. Probably the best treated room was the GR-Research room... and even then these guys weren't completely happy with the sound. This room had a kitchen with a window cutout into the main room. It created a low bass suckout (and sure enough, Tyson mentions bass in his review). We spent hours Friday evening building a false wall of 2x4s, pressboard, and foam to plug the 4'X6' window. Then they tweaked some of the 10 or 12 diffusors for the upteenth time. For those sticking a plant in the corner and calling it done... I don't get it.
I wonder how many of those throwing stones about room setup have ever done it at one of these shows. Maybe there should be a contest at RMAF for some of you to show us your prowess at room setup?
How long does it take for things to settle down in your system, in a room you know well?
I tried it in 2010 at LSAF. That was the toughest thing I ever did. I thought it would be a cakewalk. My great sounding home system that was very well broken in sounded like crap. Only after Seth of Virtue loaned me a battery powered modded version of my amp did it started sounding good. Many said I had the most natural sounding system at LSAF, but the sound never came close to what I have at home.I was very much humbled by the experience and sure respect what the audio companies have to go through every show.
I think I know what chester is referring to here. I have noticed over the last 10 years an increasing sensitivity in my equipment to being turned off for more than a couple hours. The sonic consequence of being powered down for more than a couple of hours max, is a grungy quality to the sound that persists for about 1.5 to 2 times the duration of the powered down cycle. This became particularly evident when all components were upgraded to Jensen 4 pole capacitors in their main power supply filter banks. Apparently the Jensen 4 pole caps unform enough when no voltage is applied to them that their high frequency impedance rises which subsequently raises the power supplies dynamic impedance. The circuits involved at this point are good enough to tell you when the power supplies dynamic impedance is not as low as it is when the caps are fully formed up. This is a small price to pay however, for the blacker background and more dynamic and vivid presentation you can get from using the Jensens in the power supply. I have illustrated an extreme situation that exists within the context of my system but the negative impact of the impedance rise in the power supply filter caps due to having no voltage on them is clearly audible in the case of a number of the more transparent circuit designs now available today. The solution to the problem is to transport them under powered up conditions by plugging them into an inverter in the vehicle. Scotty
