0 Members and 1 Guest are viewing this topic. Read 99950 times.
My hope is that JTWrace is silent right now because he's too busy with his soldering gun
I'd love to get my paws on a set of these... http://www.6moons.com/industryfeatures/ncore/1.htmlMartin
This amp will sound great on AC, but is at least 40% better on DC.
I listened to all the hype in 2007 ,, so I bought into it,,, my bad I used my emotions instead of brain ,, the lesson I learned the hard way was listen first.
Just curious, how did you come to this conclusion?
This is the back of the TBI Millenia. You can see that you can use 24V AC or DC to get the 32 watts per channel. You can even use 8AA batteries and get 8 watts per channel. This amp will sound great on AC, but is at least 40% better on DC.
I wished that Bruno would make a Hypex that would run on batteries.
By hooking it up to the battery and listening. A friend of mine tried it on his system and he thought it was a bigger improvement than 40%. It depends on how revealing the system is.
I realize you can hear the difference,the percentage number is what I'm wondering about. How does one go about figuring a percentage of how better something sounds over something else? Like I said before, I'm just curious.
