0 Members and 1 Guest are viewing this topic. Read 127292 times.
I thought Bruno's hometown was Leuven in Belgium.
Are you looking for a dual chassis 3 channel amp with separate power supply ? I like the sound of that. Want to make two!?
.....So if someone trips over a nice new commercial chassis not too much larger than minimum required, let me know. I propose to have a local CNC shop set it up and offer the chassis for minimal markup on an ongoing basis. Local pro labor rates are generally about 1/2 here in north Utah vs. metro rates in CA where I previously lived.
http://www.diyaudio.com/forums/siliconray-online-electronics-store/206613-some-enclosures-chasises-we-made-6.html#post2916144It has a link to the commercial siteFWIW
Look at what everyone is saying about the bass on DIY.Get the amps first.
Per the DIY thread owners of:Atma-Sphere 60W OTL (appropriate speaker load), same user owns Clayton SS pure class AAnother A-S OTL owner (forgot model, ditto appropriate speaker load)AccuphaseOther nice makes/models ...prefer their new Ncore not by small margins. Maybe every single new Ncore owner will keep their previous amp(s). It would not be a huge surprise if some new Ncore user sells an amp he used prior. My closest relationship to Hypex is I'm of Dutch descent as is Bruno Putzeys (he likely higher percentage than myself).My friend in the Netherlands now just purchased a Dutch Tent Labs amp, single tube input per channel, transformer coupling, earlier Hypex output. In direct A-B he said it's "30-40%" better than the Australian Aksa NAKSA 100 now in my possession, one of the best amps I've heard. Good designs coming from the Netherlands.Just to put some focus on the difference an amp makes, which I'm sure most readers already know. My $90 Dynaudio Esotec domes are decent tweeters, though there are definitely better. The only thing between the domes and the amp is a Dueland resistor and a killer paper-in-oil capacitor.Among other improvements, the NAKSA 100 makes the treble sound more than 100% better than the YBA. The upgrade just sounds like a completely different system. After bass modes are solved (unless you settle for no deep bass, which is completely fine and often the case) and your source is ironed out, I think many users upgrade speakers way before the preamp/amp should have been replaced. With an inferior amp you have no idea what the speakers are capable of. My 2c.
Sorry for sounding so skeptical, I am hoping this is a full breakthrough in amp design. I have been in this hobby for 40 years, heard many claims of superiority, only to be disappointed. 40+ year old Futtermans sounds better than the majority of amps, includding Class D, that are being made today. I am ready for a change.Hey earflapping, how about a review on AC with some pics of your amps. The DIY forum is so full of posts, it is hard to read everything.
They are!!! Ridiculously small and light. There is no reason they should sound this good.... (1) They are Class D. Class D has an un-natural, glossy high end which is fatiguing(2) They use an SMPS. SMPS are noisy and definitely not audiophile grade(3) They use tons of feedback. Feedback is BAD, terrible for the sound. Open loop is what real audiophiles use.(4) They are very small, light, efficient and don't generate much heat. Audiophiles all know an amp sucks if it doesn't weigh a ton and generate enough heat to warm your house.(5) They don't use tubes. Crazy. Audiophiles know tubes are required to make the music sound good, natural.
