0 Members and 1 Guest are viewing this topic. Read 20522 times.
It sure seems like the pre is important. Also some have HT bypass and dual outputs. These are very useful to people whose systems are multi-tasking.
Forgot to mention, most look for a pre-amp to add colorations, which can be very nice but I don't want everything to sound alike (have the same colorations).
A good preamplifier will have an active line stage with low output impedance and high drive current to properly charge and discharge the distributed capacitance of interconnect cables and amplifier input circuits. A passive line stage simply will not do the job because it has high output impedance and it interacts with your interconnect cables and your amplifier. You need a true high fidelity preamplifier to make your system work best.Regards,Frank Van Alstine
Charles commented... "What you will get with a passive approach is clarity, less coloration and more detail with a leaner presentation. Where it gains in tranparancy it losses in weight and what I call Soul."Interesting observation and mostly true. My concern is that it would cost me lots of $$$ to get it all in one package.
