0 Members and 1 Guest are viewing this topic. Read 23608 times.
Perhaps high end, expensive preamps will likely sound better. However, for me in my situation, I'd rather upgrade either my source, amplifier or speakers instead.
All I know is what I have experienced. My nicely modded cd player > Goldpoint/Elma stepped attenuator > amplifier > 92db sens speakers... sounds better than using any average priced preamp. I still have one but I don't use it.Perhaps high end, expensive preamps will likely sound better. However, for me in my situation, I'd rather upgrade either my source, amplifier or speakers instead.
Of course, completely understandable; didn't mean any offense. Practical considerations are prominent. I think it is beneficial to explore the pros and cons. The more knowledge, the more power one has.Cheers.
Are you referring to a buffer with no gain, or one with gain yet low impedance? Anyway.
My particular DAC has a current output DAC, not the typical delta-sigma voltage output. Thus it takes a transconductance stage, which is all discrete. So my case is not necessarily everyone else's. I do concede your point about generic CD players. I am not sure that fits most of folks cases these days. DACs seem to be more popular nowadays, but many still have opamps I am sure.I was suggesting one doesn't typically need gain, so buffers work fine in many cases.
Steve, what would be your preference for a single source cdp setup with volume control?
I have none. Cheers.
One time I see a repair tech using a CD player direct on the tube power amp and driving a low sensitive Avalon speaker, there was no volume control.You run something like this?? or use a integrated ?
