0 Members and 1 Guest are viewing this topic. Read 43833 times.
Using floor standing Maggies, how small a room is too small for a 5.1 home theater setup?Assuming the edge of each Maggie should be 3 feet away from any wall, doesn't that dictate that you will lose 6 feet from the length and width of any room? Is there a minimum recommended distance between the front L+R speakers and the front and rear speakers?
For those of you with better than movie theater sound in your homes, this would be the place to share your insights.
Can someone be good enough to answer this one?My question is about single center channel speaker placement (CC5 or CCR if budget permits): I planned to put the main speakers (MG3.7 on Mye stands) about 1.70m (5.58ft) from the front wall. Since I'm more serious with 2-channel than HT, I've been advised to install the center speaker (about 1.07m or 3.5ft above the top edge of my plasma screen) on the soffit/coffering with 3.15m (10.33ft) height and about 1.1m (3.61ft) into the room. Therefore, the center speaker will be about 60cm or 2 feet behind the main spakers, and about 1.3m (4.27ft) above top edge of the 3.7's. Is the placement too high / too far from both tv screen and main speakers for believable dialogue? Or it's quite ok to adjust the angle of the center speaker for acceptable result with this setup?The new room I'm about to build has planned dimensions of 5.95m (19.52ft) wide; 8.40m (27.56ft) long; 3.65m (11.97ft) high. I'll be sitting about 3.9m (12.8ft) from the main speakers.
Hey folks - getting a bit fatigued w/ the Krell Showcase 7 amp I'm using to power Magnepan 1.7's w/ MMG-C, regular MMGs for side surrounds + MMG-W's for rear surrounds. The Krell is just a bit too bright / brittle / "Hi-Fi" in the negative sense. Using a Marantz AV7005 processor that I got a few months back - so don't want to trade that in. Currently listening is 80% home theater, 20% music. But hoping with the right amp that ratio could change to more music.Considering a Parasound Halo A52 5 channel amp (maybe w/ an A21 added for front two channels if A52 is insufficient). Local deal has a decent deal on traded-in A52.If any of you folks run maggies for HT - or have experience w/ such - amp recommendations would be appreciated, particularly multi-channel solid state. I've got an old Conrad Johnson MV75A1 to mess around with for 2 channel audio for MG 1.7's, so really looking for something solid state for home theater with some guts & detail, but more smoothness / warmth etc than Krell. Also considering Anthem (used).Thanks!
Hey folks - getting a bit fatigued w/ the Krell Showcase 7 amp I'm using to power Magnepan 1.7's w/ MMG-C, regular MMGs for side surrounds + MMG-W's for rear surrounds. The Krell is just a bit too bright / brittle / "Hi-Fi" in the negative sense. Using a Marantz AV7005 processor that I got a few months back - so don't want to trade that in. Currently listening is 80% home theater, 20% music. But hoping with the right amp that ratio could change to more music.Considering a Parasound Halo A52 5 channel amp (maybe w/ an A21 added for front two channels if A52 is insufficient). Local dealer has a decent deal on traded-in A52.If any of you folks run maggies for HT - or have experience w/ such - amp recommendations would be appreciated, particularly multi-channel solid state. I've got an old Conrad Johnson MV75A1 to mess around with for 2 channel audio for MG 1.7's, so really looking for something solid state for home theater with some guts & detail, but more smoothness / warmth etc than Krell. Also considering Anthem (used).Thanks!
