What's your favorite Solid State Amp?
0 Members and 1 Guest are viewing this topic. Read 52982 times.
jtwrace
    • TIPP YouTube Channel
« on: 4 May 2010, 12:19 am »
That's right!  This is a follow-up to my other thread "What's your favorite Tube amp?".
Be sure to include specs!
I'll start.  My awesome Clayton Audio M-300 (Class A 300wpc mono blocks)
Thermal Protection
Power on Sequence Control
Rated power output:
300 Watts continuous rms into 8 ohms
600 Watts continuous rms into 4 ohms
Gain: 26 db
Input Impedance: 100k ohms
Power Consumption: Low Bias Mode - 300 Watts
Power Consumption: High Bias Mode - 800 Watts
Dimensions: 11.00” W by 20” D by 11.50” H
Weight: 87 lbs. each
Heat sink capacity: 0.13 degrees C/Watt Stable Temperature
Reading at Center of heat sink: 122.1° F. Stable Temperature
Reading at Right and Left Edge of heat sink: 124.1° F.
NagysAudio
    • http://www.nagysaudio.com
Re: What's your favorite Solid State Amp?
« Reply #1 on: 4 May 2010, 12:30 am »
Easy, the very best amplifier that I have ever heard is the Goldmund Mimesis 3.
jtwrace
« Reply #2 on: 4 May 2010, 12:33 am »
specs Nagy?  watts.....?
They may have the "best" amps but the website is horrible.  I can't even find that amp.
NagysAudio
« Reply #3 on: 4 May 2010, 12:43 am »
The website is not horrible. This is an old amp form late 80s, early 90s, not in production anymore. Here are the specs:
http://www.savantaudio.com/mim3s.html
jtwrace
« Reply #4 on: 4 May 2010, 12:47 am »
Then that explains why I couldn't find it...I never would've guessed you like an amp from the 80's / 90's.   :scratch:
TONEPUB
« Reply #5 on: 4 May 2010, 12:52 am »
My reference amplifier in main system, the Burmester 911 MK.3
And in system two a pair of these, the McIntosh MC1.2KW's:
TONEPUB
« Reply #6 on: 4 May 2010, 12:54 am »
Those Clayton's are really nice amps!  Every one I've heard has been fantastic!
NagysAudio
« Reply #7 on: 4 May 2010, 12:54 am »
You didn't indicate that it had to be current production. That is my personal favorite amp that I have ever heard. It originally sold for $7000-$8000, but can be found on eBay and Audiogon for as low as $1500-$2500. At this price point, it's almost a miracle of a product.
jtwrace
« Reply #8 on: 4 May 2010, 12:56 am »
 :nono:  It doesn't have to be current.  If it's your favorite, we want to hear it!   Price doens't matter at all.  We are an EOAF.  :thumb:
Equal
Opportunity
Audio
Forum
K Shep
« Reply #9 on: 4 May 2010, 12:59 am »
Parasound A21
        Continuous power output:
        250 watts RMS x 2, 20 Hz - 20 kHz, 8 Ω
        400 watts RMS x 2, 20 Hz - 20 kHz, 4 Ω
        Current capacity:
        60 amperes peak per channel
        Power bandwidth:
        5 Hz - 100 kHz, +0/-3 dB at 1 watt
        Input sensitivity:
        1 V for 28.28 V, THX Reference Level
        Input impedance:
        33 k Ω unbalanced; 66 k Ω balanced
mdconnelly
« Reply #10 on: 4 May 2010, 01:44 am »
McCormack DNA-500 - awesome amp!   Conservatively rated at 500wpc into an 8-ohm load and 900 watts into 4 ohms
TONEPUB
« Reply #11 on: 4 May 2010, 01:50 am »
The DNA 500 is a great amp....  Had one of those for a while.  CJ Premier 350 was my next choice after the DNA 500.  Still one of my all time favorites.
mdconnelly
« Reply #12 on: 4 May 2010, 02:02 am »
I've gotta hear the CJ Premier 350 someday.  That is exactly the amp that the guy who sold me the DNA-500 bought to replace it back in late 2005.
Freo-1
« Reply #13 on: 4 May 2010, 02:03 am »
Nakamichi PA-7.
Great sound at a reasonable price.
TONEPUB
« Reply #14 on: 4 May 2010, 02:11 am »
That's exactly what I did with mine too!  Kept the 350 for almost five years until I got the Burmester.
zybar
« Reply #15 on: 4 May 2010, 02:39 am »
My top three are:
BAT VK600SE
Pass XA 100.5
McCormack DNA-500
Of course none of these float my boat like the Atma-Sphere MA-1's...   :eyebrows:
George
jtwrace
« Reply #16 on: 4 May 2010, 02:40 am »
George
You're killin' me George.
zybar
« Reply #17 on: 4 May 2010, 02:45 am »
I'm trying...
George
Occam
« Reply #18 on: 4 May 2010, 03:14 am »
My faves are -
1.Hugh Deans Aksa Soraya, and soon hopefully his Maya. Hugh Aspen Amplifiers has his own circle on AudioCircle
http://www.audiocircle.com/index.php?board=19.0
2. The Korato and Korato Anniversary represented here in the States by a frequent poster, Brian Pape
Paul
arthurs
« Reply #19 on: 4 May 2010, 02:04 pm »
There are some fantastic SS amps listed above.  I had a chance to demo the Vitus SM-010 mono's in my system earlier this year, wonderful amps that I believe deserve mention with some of the others already noted in this thread....
