0 Members and 1 Guest are viewing this topic. Read 341716 times.
Yes the Tranquility would definitely be worth considering. Avail yourself of the free trial and check it out.ThanksBill
I assume you have volume for iTunes (or whatever you're using) set to maximum.Anyway, is the problem that you can't get the stereo as loud as you want or is it that you're uncomfortable the volume knob is set so high? If the latter, what's the harm?Strange though. Tranquility DAC has 2V maximum? Input sensitivity of your amp should be 2V or less. If it isn't, there's your problem.
Eric has done extensive tests showing that a Mac Mini is the best source - but others work on it just fine.ThanksBill
Where's the data on that?
Probably somewhere in the previous 46 pages of this thread...
