0 Members and 1 Guest are viewing this topic. Read 403638 times.
--there's just a lot more music in 16/44 than most people have experienced (including me before I took a chance on the Tranquility DAC under the introductory pricing).
Right on, Dave.Since all of my music is on my computer, I did a calculation and found that about 98% of my music is 16/44 and 96% of my new music purchases are 16/44. The vast majority of what I have and would be interested to purchase is not high-resolution. And like you I've found that the Tranquility (and then the SE) make 16/44 sound much better than high-resolution files sounded on my previous DAC. And I'm not a vinyl/tube person. I've had solid state and CDs for 20 years. I'm happy with detailed and accurate sound--there's just a lot more music in 16/44 than most people have experienced (including me before I took a chance on the Tranquility DAC under the introductory pricing).
The thing that never ceases to amaze me is the NOS DAC that is in the Tranquility is old enough to vote in every state in the Union. Many of the discs that I have are from the mid eighties and the Tranquility SE is stripping out information that my Cary with its' 8 (yep, count 'em EIGHT) PCM1792's had no clue was there or got wrong. Part of the beauty of the Tranquility DACs is that ultrafi had the foresight to know that less is more in digital audio design and then to use the BEST parts for each aspect of that design - not necessarily the most expensive - just the BEST.
Hi DaveAbsolutely. The Tranquility DAC guys are not the only ones to find this out. A number of people I know who have built and designed DAC's simply could not find a modern chip better than PCM1704 or a Phillips double crown. It's not confined to DAC's either. Mike Lenehan of ML1 fame uses Peerless HDS Woofers because he tested tons and found it the best. Sigfried Linkwitz measured their distortion and found it second only to the Seas Magnesium - and the difference was not much. Yet because it doesn't cost as much as other drivers some people poo poo it. Go figure.ThanksBill
Hi SteveI would get the Tranquility SE first - it will work fine with your current Windows machine - just not to its optimum thats all. Then look into getting the Mach 2. I have used the Tranquility with a Windows machine and it was still better (to my ears) than some other USB DAC's such as the WFS.ThanksBill
Hello,I am following this thread (and the Mach2 one as well) and am having a little trouble deciding about which to buy first: The Tranquility SE or the Mach2 Mini? Presently using a Windows 7 machine (upgrading to an Antec 1200/850 watt PSU case,MUCH quieter it should be than my present one,but this will be used for video and other processes),and I have really no experience using the Mac O/S (it is Snow Leopard,correct?).I'm awaiting a reply back from Mach2 on some of my questions,and would like to make a decision to purchase one of the two this weekend. I'm not really crazy about using a 1/8 mini out for audio until later when I can get the Tranquility.. (I also use a Joule Electra tube preamp and McCormack dna-0.5 dlx Rev.A SS amp.)Thanks for any feedback,I'll be tuning back in after work tonite.Steve
I agree with Bill. Get the Tranquility SE and go along your upgrade path from there. Eric Hider is also available for great advice. I am using my Tranquility SE with McCormack equipment. Sounds great! Regards, Din Dayemi
OT: I'm curious if anyone who owns a Tranquility has listened to Electronic music,particularly analog recorded stuff,like this one I have,VA - Electronic Toys or VA - Gravikords Whirlies And Pyrophones?Or Yello? "Ohhh yyyeeahhhh!"I'm almost keen to buy the DAC just for fun music like this,to see how it all works together. Nevermind. :/ (Honestly,Music holds a dear place in my heart/mind and I feel we humans might benefit for finding ways to bring more and better quality of it into one's life.)Steve
Thanks for your feedback guys. I've been following this thread and the Tranquility DAC/db Audio Labs for some months now. I'm looking for #1,a great product and #2,quality customer service.
hey guys, just ordered the Tranquility DAC...which powercord would you get if on budget?...looking to spend 100-150.00 for used at Audiogon...thx.
Is it the SE? If not then its designed so power chords are not that important. If it is the SE then get the best one you can afford. I used a MIT second hand one on mine to good effect but an acquaintance made some up for me that was more expensive and it was better. Put the MIT's on my amp instead and it sounds better. But Dave of PI Audio is sending some out with a Mac Mini Power chord that is supposed to be really good - but more expensive again.ThanksBill
Yes get the 2010. I'm getting one when my tax return comes back. I havn't heard the two compared in person, but the people I trust that have, say even stock the 2010 is as good or better than a tweaked 2009. The 10 can be taken further with the upgrades too.+1 on the customer sevice being the best in the biz!
Next I need to get the Mac Mini...should I go 09' MM or just pay the ectra price for the 10' model???...can the 10' MM really be better than a souped up earlier year MM with all the tweeks that Eric tells you to do???
