0 Members and 1 Guest are viewing this topic. Read 9410 times.
Yes Wind Chaser I remember well the Salad Bowl Affair. Never did give them a try as I was worried the vinegar and oil might stain the carpet as it dribbled out (sidewalls of the bowls being too reflective a bit of romaine with Paul Newman's Own was recommended to line the bowls).
Here's a reprint of an email I sent to JimThis sounds sort of odd, but yours was the first audio product I bought that I did not want to like! I mean, they are kinda ugly, no matter what color you dye them. Plus, I wanted to believe the designer of my fairly expensive speaker knew what he was doing.So after countless hours of taking them off and putting them on....you know what? I can not listen without them. It makes a big difference. So much more of a natural sound, even w/ all the room treatments I've added.I long ago lost the velcro tabs (have to pick up some eventually) so I've held them on w/ small strips of duct tape, which eventually fail. If I now listen, even without looking at the speakers I can immediately tell if one or both 'woolie pads' have fallen off.Got to hand it to ya!Howz that for a weird review?
Thanks for that Robin. I'll look for that. The woolies do work, though don't they?I first thought they rolled off the high end too much. That's why I kept taking them off. But it finally dawned on my tiny brain, that it sounded more like 'real' music and less like 'hi-fi' with them in place. Sometimes, it's hard to let go of preconceived notions of what is correct.Seem like a good explanation?
