0 Members and 1 Guest are viewing this topic. Read 23930 times.
OK, so the new iMac is here and it's amazing. Seriously. I have never seen such a beautiful piece of machinery.
Yes, you can plug your cable modem right into the Ethernet port of the AEx and use it as a wireless router.
Quote from: Crimson on 15 Dec 2009, 05:54 pmYes, you can plug your cable modem right into the Ethernet port of the AEx and use it as a wireless router.Interesting...my Linksys is about done. Is the AEx better then a standard wireless router? is it "N' compatible?
I had a question about the AExpress router... Can I just hook that directly into my cable router via Ethernet and use that to broadcast a wi-fi signal throughout my house? My brother-in-law said I need both the Express and the Extreme base station to do that, but I can't see that on the Apple web site. Any help?
Fantastic! I can't wait to get mine and hook it up. Is the N noticeably faster than the G?
2. The DVI-HDMI adapter may still conform to DVI distance limitations (around 15'). An active converter may be more appropriate.
Does anyone make a good terminated 3.5mm mini to toslink cable? Or should I just use any adapter?
