0 Members and 1 Guest are viewing this topic. Read 248193 times.
.....(given that I'm committed to some kind of PC audio option).
Quote from: chadh on 9 Nov 2009, 07:28 pm.....(given that I'm committed to some kind of PC audio option). Chad, Have you given any thought as to whether you will have high resolution audio files in your library? If you plan to have your music library contain 24/96 (or higher) files (as I do), you won't be using the USB input, as that is limited to 16/48 due to the USB chip used. (I believe that limitation would apply to the Music Hall 25.2 DAC as well) If you do, you would need either an S/PDIF output in your computer (integrated or soundcard) or a separate USB to S/PDIF or FireWire to S/PDIF converter. In either case, I am hoping that the "Patented Time Domain Jitter Eliminator" works well (well enough to have already been awarded an actual patent, as it doesn't say patent pending, but says "patented"!) Steve
Suggestion: Have a switch on the front panel to select which input to decode. Sabre is capable of doing it. Then, people can have their PC, PS3, and other sources connected to the DAC and can use the DAC as a pre-amp.
And the W4S model has the greater price that would one would associate with a discrete output stage and balanced design...
The volume will still be there and it cannot be bypassed.
Quote from: bravophase on 10 Nov 2009, 02:19 pmThe volume will still be there and it cannot be bypassed. 1. So, does that mean it is an analog volume control versus a digital one? 2. Is the tube inside the casework, or does it extend through the top or mounted completely on the top? Do you have approximate case dimensions? Steve
Quote from: srb on 10 Nov 2009, 02:47 pmQuote from: bravophase on 10 Nov 2009, 02:19 pmThe volume will still be there and it cannot be bypassed. 1. So, does that mean it is an analog volume control versus a digital one? Hi Steve,1. yes it is
