0 Members and 1 Guest are viewing this topic. Read 14997 times.
My Omega 5's must be the newest version, since I just upgraded from my XRS 3 to the XRS 5 status with Louis help.In regard on Hornshoppe I am refering to the newest version also.
Has anyone compared the Hornshoppe to the Omegas side by side?Feel free you send me your opinion via a message or email, if you do not want to post it on this Omega site.
It really depends on the amp you are going to use.
It also depends on where the speakers will be placed. The Horns can be placed out in the room or in the corners but the presentation is very different depending on where you'll use them.
It also depends on where the speakers will be placed. The Horns can be placed out in the room or in the corners but the presentation is very different depending on where you'll use them. These speakers can play VERY LOUD.Can you elaborate on what the differences are?
I've got the Horns with the newest driver, the Fostex FE126EN. They really have proven do be great speakers and they fullfill my needs a lot better than the Omegas ever did.The Omegas go into a toattly differen sonic direction than the Horns. The Omegas seem to bring out the details a lot, due to the tilted up upper extension, but they lack extremly in portraing a music instrument in it's actual size.The Horns (especially with the newest driver) cover the frequency response from the lower octaves to the higher octaves very well. They sound true to size and have a great goggie factor. Sometimes I wonder how the other (larger) Omegas sound, but than I tell myself that I really do not need another speaker, besides the Horns.I have tried using the Horns with my subwoofer, but 98% of the time the subwoofer does not extend the lows by much and is really not needed.
