0 Members and 1 Guest are viewing this topic. Read 8245 times.
isolation transformers on ebay. they can be had for pennies on the dollar. hard to do w/amps, tho, as they need to be wery big, which means heavy, and the big ones usually hum a bit, which can be bothersome. you want to make sure that the amperage rating of the iso tranny is at least as large as what you are plugging into it. for your front end, these will reduce the noise floor. i would recommend at least one for dac, one for transport, (or only one if you have a single-box cdp), and one for preamp and all other analog sources. (if you have h-t, isolate anything digital w/its own transformer.) short of serious money, for things like balanced power conditioners, these are the way to go on the cheap, imo. danny ritchie has found something relatively cheap for a commercial product; see this thread:http://www.audiocircle.com/index.php?topic=68006.0and, this liebert ups based power supply also looks good, if found on ebay; otherwise big money (it's talked about in this thread):http://www.audiocircle.com/index.php?topic=70904.0hth,doug s.
doug, Do you mean something like a Tripp IS250 which has a street price of around $100?http://www.tripplite.com/en/products/model.cfm?txtModelID=226
$20
I'm not convinced that a power conditioner really has a place in cheap and cheerful hifi systems. Has anyone tried them out in such a system? (see the guidelines if need be)
Note: Don't do this stuff unless you know how.
I just drag the garden hose into the house and spray down my breaker box.I do this bi-annually to help keep the grime cleaned off.Sometimes, I'll have my son use the steel handled toilet brush to scrub the contacts while I'm hosing it down. Afterwards, I'll douse the panel with an entire can of WD-40. That does a great job of displacing the water and keeping it dry.You results may very of course.Bob=================================================== EDIT: My conscience (actually it was the conscious of a fellow AC member) got the better of me. My attempt at adding one more to the Darwin Award nominees was in poor taste. I should not take advantage of the lesser mentally capable than myself by encouraging them to shoot a thick, high volume stream of water into a large metal box filled with lots of pissed off electrons.My apologies to the spouse of anyone who actually tried my idea. But someday you'll come to learn I've rescued you from your poor choice in parters. It would be best to search the classified ads for a lonely audiophile. Again, you'll thank me.Cheers.Bob
