0 Members and 1 Guest are viewing this topic. Read 13913 times.
HI,I do not have a lot of experience with different bass drivers, I came from stand mounters plus sub to my current system. Having said that, I also use Vifa 10' drivers in Onken style cabinets to complement the speed of my Lowther horns... with variable cross over point and independent amplification I find them integrating well and providing a tuneful and when required substantial bass response.Cheers,Ken
Nice terry j. I have never played with anything larger than 12", although I do have a pair of Hawthorne 15 Augies, but have never set them up. I have read that larger driver would not need to travel as far for the same levels, which I suppose in theory, should keep distortion down.How do you have them loaded?Mr C
Hi Terry, I'd love to come over at some point during that weekend. Not absolutely 100% sure at this point but can't see any reason I can't be up in Bx that weekend.Hey, a new thread couldn't hurt
Hey Terry feel free to start a thread, not my circle, OUR circle. Hey we have never been to Bathurst,. But we have a few kids, so we would need to bring a tent and setup in your backyard, or something. Sounds like a good idea, I could bring a nice pair of open baffle speakers for a listen, a couple of diy tube amps.. Start the thread and lets see what interest we get.Mr C
Terry, that's a really interesting speaker. On the face of it, the PHL looks like overkill but I'm using some smaller 6" PHLs in MTM configuration and I've always considered them to be more like a 4" driver in respect of their short travel and the amount of air they move. They don't go too low but they do mid very well.
I guess your 18" PHLs are moving about the same amount of air as a 10" or 12" with twice the travel. Short travel speakers often get bad-mouthed when they're compared on the basis of similar diameters but if the comparison is between drivers that move the same amount of air it's a bit more real.
Do you have any views on the relative difference of sound quality when your comparing a narrow column of air being moved by a long throw driver with a broader column of air being moved by a short throw driver? [or perhaps I should just ask you how you came to create that design ?]jules
There is simply NO comparison! It is one of the perennial questions I have whenever we compare my bass to other bass.
One thing I suspect that is part of the answer, these reproduce the leading edge of the wave, the transient start of the signal, those complex portions that make up the 'percussive' sound. The thing about percussion is the attack, that initial 'bang' of the wave.All drivers will get the main portion done, the overall shape etc, enough to give you the idea of what is going on, but it is the detail these bring out in that that is outstanding.
Two PHLs and a Raven in D Apollito eh? Feeling psychic this morning....Pat have anything to do with that?
Terry,thanks for the great reply. If it hadn't been for the fact the you're using a PHL my thinking might have been that it was overkill but I assumed that the specs of the 18" are like those of other PHLs [low Qts, high efficiency, a magnet the size of a small football field and high BL] and figured the speaker probably had a strong rationale to its design.
That dramatic eh?!
The specs make them dynamic/details drivers don't they but the wizard move has been to use that massive diameter to make up for what is usually the weakness of short travel. Do you think the cone weight/strength might be the limiter as far as bass goes? I don't say that as a criticism but it looks like the trade-off.
Very Close ! They're a parts only kit from Zalytron in the US. I don't like the xovers all that much but a re-design is beyond my skills.
The single most common comment about my system when people hear it is 'it is not an audiophile system' and strangely enough the wording is pretty well identical between people! funny that.And the comment is never dismissive or a put down, but a genuine compliment.
