0 Members and 1 Guest are viewing this topic. Read 8914 times.
I still have two dips centered around 47 and 97Hz that I would like to improve upon. According to my calculations they are both tangential in nature.
What if I straddled that cathedral peak with a drop ceiling a bit below that center beam.
It's possible those nulls are tangential, but you really need to measure in several locations in the room to be sure they're not just positional. That is, you measure where you listen, then move the microphone six inches forward or back and see if the frequencies change. Then measure again two feet forward and/or back. If the frequencies change, they are not related to room modes.
To be sure I understand you correctly, if the null remains but changes in frequency, then it is positional.
I already have 6" thick OC703 panels floor-to-ceiling in the corners and 6" OC 703 panels behind the speakers.
What boundaries are the potential tangentials involving? If it's 4 walls, that's possible, or as Ethan said, it could be positional. If the theoretical tangentials are involving the height at all, it's doubtful as your ceiling is not flat and parallel with the floor the way most of the calculations assume.
Rectangle rooms have 12 corners, not only four.
I'm not wise but I also would think about the proportion of bass traps to other reflected surfaces in the room. I like a fairly live room for the mid range & up. Unfortunately, as you add more absorption to tackle bass issues <300Hz, you are almost always adding more absorptive capability from the mid range on up.So... I'd experiment before adding anything permanent. That way you don't put in a drop ceiling, and end up with overall worse subjective results although have slightly better measured bass response.
Finally, RealTraps are designed to absorb a wide range of low frequencies. Some bass trap designs are based on a Helmholtz resonator which is tuned to a single problem frequency. While a Helmholtz trap can reduce standing waves at the one frequency it's tuned to, it does nothing for the harmonically related frequencies nor will it reduce low frequency reverb across the entire bass range. Since RealTraps products have a broader range they are appropriate for any size room, and they also reduce reverb time at all frequencies making music played in the room sound much clearer.
Speaker positioning directly effects the intensity of room modes. My current placement offers the best balance with the flattest response. Can the positions of the speakers also have an effect on non-modal peaks and nulls?
Is broadband absorption still the best answer to the non-modal problems? Besides changing the listening position, which may only shift the null to other frequencies, is there a solution, or is this just one of those things to live with?
I am thinking that center wall treatments will help with that tangential problem at 45Hz. Am I on the right track this time?
