0 Members and 1 Guest are viewing this topic. Read 10671 times.
Hey Ed,Yes, absolutely!! Bondo is great.The last time I used automotive body filler was.....um.....1986.In some of the photo's you can see gray putty. That was a "general home use" two part epoxy. It's very easy to work with. I've had that can for well over a decade, so I'm not sure how much it costs. The Bondo I bought last week (looks red/pinkish in the photos) is one gallon and cost $20 at AutoZone. You can buy a plastic "knife" (spreader thingy) for $1, but the fine sharp edge gets beat up which leaves high spots you'll have to sand down later. Something like pieces of thick poster board might work just as well and be a lot less expensive, although making these three baffles you might only go through three spreaders so it may not be a big deal anyway. Regarding my previous baffles (back in 2007?) I was using fiberglass cloth and resin over a wire mesh with a wood skeleton. I'm NOT a real big fan of fiberglass cloth or resin. If memory serves, I filled in the low spots with the same can of household epoxy I used up on these.But yea, Bondo is very easy to apply, very cheap, sands easily...and actually smells good (subjective, of course). Bob
