0 Members and 1 Guest are viewing this topic. Read 20319 times.
P.S. I just realized yours doesn't have fuses. I wouldn't test this as is. Also, the ground is only partially covered. This is no problem if this were incased with strain reliefs. But as is, the wire could be moved by force and cause a short. This is somewhat dangerous in its current state.
with the board it is not possible to wire the cmc wrong, isn't it?
The dc filter should have no input caps, and you don't have to use line rated x2 caps. Anything up to about 10-30uf on the output side should be fine. Make sure the cap's voltage is at least 25% over the switcher's output voltage, and if you use electrolytics, be sure to use the proper polarity.
