0 Members and 1 Guest are viewing this topic. Read 20345 times.
hiyes they fit perfectly on the boardsthe wattage of the 9 Ampere multiply it with 115V !!SO if your amps stays under 1000 watts, no problem I used the caps as described in the forumbut if i was a bit richer i would have choosen for the Auricaps same valuestake >200V even if the wall current is 115. but just to be sure in excess conditions.however Auricaps are not officially registered to be line level capsFamous line conditioner brand(s) use them thoughthey do sound better, (much) more musical
Has anyone ever tried Auricaps in the Felix? I think I'm going to give it a shot.
Quote from: yammy1688 on 20 Mar 2009, 06:03 pmHas anyone ever tried Auricaps in the Felix? I think I'm going to give it a shot.Yes I have. They are however not X rated, so do so at your own risk. I liked plain vanilla Jantzens better though and they are cheaper. Also not x rated.
Would you care to elaborate on how you felt the Jantzens bettered the Auricaps?Quote from: JoshK on 20 Mar 2009, 06:04 pmQuote from: yammy1688 on 20 Mar 2009, 06:03 pmHas anyone ever tried Auricaps in the Felix? I think I'm going to give it a shot.Yes I have. They are however not X rated, so do so at your own risk. I liked plain vanilla Jantzens better though and they are cheaper. Also not x rated.
Joshcan you link me to a post of yr OB speaker adventures?Do you have made yr mind up how to construct your OB setup?
