0 Members and 1 Guest are viewing this topic. Read 88307 times.
Drats ... just checked my copy of Famous Blue Rain Coat .. no BOTRH! I wonder ... once the procedure is almost complete and you tweak the toe-in, does toe-out (by the same number of degrees) provide the same benefits ...
Interesting info on speaker positioning:http://www.genelec-ht.com/learning-center/faq/acoustical/bass/
Hi All,Today, after about a 24 hour period of musical celibacy to allow the ears to settle down after days of rooting around with the system, I fired it up with the intention to have a pleasent session. I was nearly blown out of the room as I had set the volume to the usual position. Now after setting the speakers I have to use about 15-20% less volume for a relaxing session. When the volume is up a bit, nearly to the "old" volume setting the system now produces much more punch/dynamics than before "Master Setting".rough notes made by my uncle on the subject of speaker placement dated 15-10-59.It would appear that there is very little difference between his notes and Master Set principles. There is one very interesting comment that could give some light on why is it so. " From experimenting with speaker box placement (stereo) there appears to be a correlation between speaker cone angle allowing the music 5to be opened up filling the room more or less evenly. The listener, if in an central listening position, observes the inside of a speaker cone, with the side to the centre of the room is on more or less perpendicular plane to the listener. I deduce that if the listener in the central position with the focal point of the speakers set 1-2 yards in front of the listener is subject to a wider dis bursion of sound waves rather than if the speakers were facing directly at the listener. This creates the illusion of a wide musical area similar to listening to a orchestra on a stage, IE, wall to wall sound in front of the listener without a dedicated focal point. It must be the angle of the speaker cone in relation to the listener that provides a detailed but wide listening area."All very interesting. Another discussion point on speaker placement? Cheers, Laurie.
aa Well I figure I’ve finished my fiddling with speaker positioning for now. A bit like Laurie, I took a few days respite and thinking about what Dave (dcstep) suggested, started with my LH speaker first this time and found I was very happy with the base response at a point only about a few cm closer to the rear wall and laterally, pretty much the same as before. Then I repeated the exercise of moving the RH speaker as discussed throughout this thread and finally played quite a bit with the toe in though again ending up again much where I started. Again, less than a couple of cm total change for the RHS side but well worth the effort.What worked best for me for final minor positioning and finding the best toe in, came from focussing on a vocalist – ideally central and close miked. When the speakers were just about spot on, the central image seemed to suddenly lock in and wherever I went in the room, the vocalist stayed imaged perfectly in the centre and perhaps even a foot or so forward of previously. It was Hugh that first noticed and pointed this out to me and the last sessions have been me refining this. A cm or two out in positioning and the sound that may be quite nicely imaged when in the sweet spot, came much more from the speaker I was in front of when I moved laterally. Whilst I have now ended up with what seems to be a very slightly narrower soundstage, it is far more tightly focussed and hence realistic and 3D (deeper) than before and I’ve eliminated what I had perceived previously as a slightly thin and recessed midrange response.I had always read of needing fine adjustments to get speaker positioning just right but never knew how to take that final step. Just so its clear to all, I have not been able to fully perform all the MS procedures as documented. I am quite constrained in my available range of speaker positions for example and the speakers are almost certainly closer together than ideal under MS principles. However, I've followed them as closely as possible and I’m much, much happier with my room set up now from using them as best I can so thanks again to Steve and everyone who has contributed this thread.
Steve,Thank you very much for your thorough explanation of Master Set. I am most grateful!See you on 27th......Cheers,Hugh
Thanks Mucho Steven! I can tell you really love this stuff!Here's a floorplan of my listening area. This old drawing pictures speakers against the 22' long wall, pointing into the kitchen echo chamber. I moved the speakers to the fireplace wall recently, which sounds better with typical tape measure setup. Eventually I will try Master Set on the long wall again, but mght as well see what this wall can yield, as it suits the lifestyle concerns better. I did use the Cowgirl song. Maybe the soundstage depth parameter is a good reason to explore the potential spots further out into the dead zone, giving a few more inches of depth. But I took the first spot and I liked the depth. It just isn't artificially deep sounding as it was before when baffles were 6 feet into the room.I started with no toe, I enjoyed it OK, but a little brighter than what I'm used to. But you're right the toe for Master Set seems to be different than regular setup when you can tweak the soundstage with the toe. Speakers' specs are usually measured headon, so that should be the flattest unless speaker designer says toe it out. The midrange midbass was seriously intense. Fun but takes some getting used to. The whole impression of the 1st Master Set was intense. A 1932 recording of Schnabel Beethoven Sonata was riveting, easy to ignore the terrible recording noise.You said, "I've noticed that the speakers I've seen in the professional MS's are toed in quite a lot. I can't argue with the results."Do you mean pointing directly at the listener, or toed in even more (crossing in front of listener?)ThanksRich
Rich- Mahalo for posting the floorplan of your listening room, it makes these discussions of Master Set speaker placement a lot easier to understand.Steve- how about posting a floorplan of your listening room with your Master Set placement and equipment?Hugh- what happen to the picture of your listening room?DanMy Current set-up: Duetta w/U-byte cable->Aberdeen Tact RCS 2.2XP->Aberdeen Tact S2150->Volent VL-2s. Other digital sources: Theta Jade and AppleTV via an upgrade Genesis Digital Lens.
