0 Members and 2 Guests are viewing this topic. Read 96766 times.
Just ordered my first turntable in over 25 years, a Rega RP-6 with Exact-2 cartridge. Since my preamp doesn't have a phono stage, I also ordered a Rega Fono MM phono preamp. The cartridge will be factory installed so I don't think the setup should be too challenging. In anticipation of this purchase I've bought about a dozen LP's to get started.I don't have a record cleaning devices, not even a brush. I expect the turntable to arrive Wednesday or Thursday. Any newbie advice or suggestions for getting started would be welcomed. Bob
Smart people, is there a rule of thumb on $ spent on cart vs cost of turntable ? or go with the most expensive cart you can because the cart makes more difference to the sound than the TT ,no??thanksScott
