GR Research OB-5 MTM Top Sections w/crossovers $295/Pair!!! lower price!!
0 Members and 1 Guest are viewing this topic. Read 1038 times.
lhunsic105
I have a custom pair of open baffle GR Research (OB-5) (Just Tops) with assembled crossovers in a box for sale that use GR Research OB-5 MTM Top Sections mounted on a OB Truncated Pyramid  Baffle 8" Top 10" Bottom, 24" high.
The MTM section (as in the GR Research  OB-5/OB-7) consists of a pair of M-130/16's crossing in the 1,800Hz range to a BG Neo 3 pdr. The crossover point of the open baffle MTM section to the OB  SW-12-16FR woofers  is in the 200Hz range. The  OB-5 sections  have 91db sensitivity with 1 watt/1 meter and have about a 6 ohm average impedance load with a minimum impedance that drops to 4 ohms in the 4 to 5kHz range.
I purchased the drivers,  crossover parts,  and plans from GR Reseach.  The Crossover components include Alpha Core foil inductors.combined with Erse poly caps and Sonicap Gen.2 by-pass caps and Sonicaps.    Resistors are Mills and Lynk  The crossovers are wired with JPS Labs wire from Danny approx. 35 feet.  These were mounted on a w frame servo feedback bass section that I will be selling at a later date for $425 each.   OB-5 Tops.....$295/ Pair w/ crossovers from Danny.  I also will include schematic..  I have pics I can send.  Can ship!!! Parts cost over $650!
http://http://cgi.audiogon.com/cgi-bin/cl.pl?spkrfull&1232999025&item
« Last Edit: 13 Dec 2008, 01:23 pm by lhunsic105 »
