0 Members and 1 Guest are viewing this topic. Read 19370 times.
The 91 dB sensitivity seems low, I thought sensitivity would go up adding a 2nd driver? It is an interesting design, I can't predict how it'll sound compared to a conventional BR....
I'll have to think about it a bit more, but my 1st inclination is tht we have an acoustic 2-way system. Front baffle FE126 will have dipole roll-off way up high. Enclosed FE127 (or FE126) will produce below that, and the big magnet of the FE126 is going to block most of the destructive interference from the 2. Next thing to think about is whether they are wired in phase or in anti-phase.Seems to me that this eliminates the problems of 2 FRs used FR (and Ed;s over the top Model 3 belies some of those)and introduces a whole bunch more (and potentially much more).dave
They would have to be in phase for the claimed cancellation of the backwave to occur... I also don't believe the cancellation could actually be as complete as they claim. But if it sounds good, it sounds good I guess. No way to know unless you try it with something like this.
Quote from: DaveC113 on 29 Sep 2008, 03:44 pmThey would have to be in phase for the claimed cancellation of the backwave to occur... I also don't believe the cancellation could actually be as complete as they claim. But if it sounds good, it sounds good I guess. No way to know unless you try it with something like this. Do these points make sense?If in phase, the volume in the gap remains the same, which gives much the same result as just an OB, since the impedance of air is so low compared to the driver.dave
FYI, I learned that the drivers are wired in matching polarity (in phase), and the excursion and power handling of the ob driver is controlled by a "transient perfect enclosure with mutual inductance coupling". According to Eric, fidelity and power handling goes through the roof.
I've just purchased a pair of them. The lack of definitive responses only made me more curious so I decided to call Tekton Design. I got with Eric Alexander and asked him a bunch of questions.After a lengthy discussion with him, I'm completely sold on the concept. Since I got to talk to Eric, I have purchased them without reservation.FYI, I learned that the drivers are wired in matching polarity (in phase), and the excursion and power handling of the ob driver is controlled by a "transient perfect enclosure with mutual inductance coupling". According to Eric, fidelity and power handling goes through the roof.I'll report back once I have them in hand.
I'm curious how sensitivity drops as well....
why couldn't something else that doesn't immediately make sense, work?
What interesting concepts! The speaker is one, and the DIY license is another one. I wonder about the patent-worthiness. The combination of a dipole and a monopole is called a unipole. That is not a new invention, though a good one. The same goes for compound mounting of two drivers. So what's new? The fact that nobody combined those two things in one speaker before? Or the fact that both concepts are usually only applied for woofers and subwoofers?
I've had the speakers running for a while now...they're well on their way to being fully broken in. My initial impressions are that the technology works...the sound is open and airy. Build quality is great and visually, they're cool. They image great as well.Definitely a thumbs up!
