0 Members and 2 Guests are viewing this topic. Read 767689 times.
I ordered some k40y's from Rutube but they have not arrived .
FWIW, I've injected some K72s with Fluorinert (liquid teflon), with interesting results. I'd call the injection experiment a success. The resulting cap is a sibilance killer. If you want to test a few, I'll send you a pair (low value). I can also send you a pair of porous teflon in Fluorinert capacitors I had wound for me. Far out holophonic beasts!
has anyone here ever had experience w/hovland musicaps?thanks,doug s.
Quote from: doug s. on 4 Jun 2008, 01:14 pmhas anyone here ever had experience w/hovland musicaps?thanks,doug s.Now we're talking more mainstream.Ray
Quote from: Ray Bronk on 4 Jun 2008, 01:21 pmQuote from: doug s. on 4 Jun 2008, 01:14 pmhas anyone here ever had experience w/hovland musicaps?thanks,doug s.Now we're talking more mainstream.Raymundorfs, vcaps, sonicaps are also mainstream, afaik... as my almarro a205a mkll came w/hovland caps, i am curious about how they stack up...doug s.
Quote from: doug s. on 4 Jun 2008, 01:44 pmQuote from: Ray Bronk on 4 Jun 2008, 01:21 pmQuote from: doug s. on 4 Jun 2008, 01:14 pmhas anyone here ever had experience w/hovland musicaps?thanks,doug s.Now we're talking more mainstream.Raymundorfs, vcaps, sonicaps are also mainstream, afaik... as my almarro a205a mkll came w/hovland caps, i am curious about how they stack up...doug s.You're right Doug F, but several posts back, people were offering to send him caps I've never heard of before. I'd like to hear John L's word on the Sonicap Gen I. The gen II, is from what I read a bit thin sounding. The Gen I is reasonably cheap. Ray
If they came stock then they must be crap. Go out IMMEDIATELY and shell out hundreds for teflons. All kidding aside, the teflons just have something that the others don't give you. I would suggest that if you don't want to replace a full 1.0uF cap with a very expensive teflon, then get some of these Russian .1uF teflons, if they will fit, and install a bypass over the old caps. You will get 95% of the cure for a lot less money. Enjoy,Bob
