nice to combine with http://www.tempoelectric.com/caps.htmto get triangulation in acquiring data
Quote from: kyrill on 4 May 2008, 03:48 pmnice to combine with http://www.tempoelectric.com/caps.htmto get triangulation in acquiring dataTriangulate? More like quinteplate. Just when you thought VCap Teflon can do no wrong, you can read something like this for contrarian views:http://www.sixmoons.com/audioreviews/caprolling/caps.html
You cannot simply pick a "favorite" capacitor and use it everywhere.
No, but as per my post above, you can pick one you don't care for anywhere.
On a totally different note, I would love to be directed to any threads about headphone comparisons used as a neutral reference for recording. I'm getting increasingly mistrustful of my Sennheiser HD 650s and Etymotic Research ER 4Ss as they seem to error on either side of the line.Thanks again.
As above, thanks for the delicately written and researched review. As much as I'm interested in caps for the tube coupling application that was your context, I also have need for very small voltage coupling in SS, say 16VDC, as well as the very different context of speakers, both of which I'm sure would reveal different results. Also curious about experiences with DynamiCaps and Duelunds.On a totally different note, I would love to be directed to any threads about headphone comparisons used as a neutral reference for recording. I'm getting increasingly mistrustful of my Sennheiser HD 650s and Etymotic Research ER 4Ss as they seem to error on either side of the line.Thanks again.
Well, I really wanted to further compare Mundorf silver/gold vs. silver/oil, so..---------------------------------------------------------------Mundorf silver/gold vs. silver/oilI finally did some proper comparisons between these 2 capacitors, and while they do share the musical Mundorf house sound, their differences are significant enough that one should not automatically think a system synergistic with one will be synergistic with the other.There are some who have concluded silver/gold is "not as good" as silver/oil, but I would not agree with that conclusion. However, they have sufficiently differing presentations and gestalt that yes, one "may" definitely prefer silver/oil in a given setup/preferences. One word I would use to describe the main difference is "liquidity." While both are remarkably smooth, silver/oil has more liquidity, not enough to obscure detail but just enough to "massage" recordings that are not perfect. As a result, I am able to enjoy more percentage of my recordings through silver/oil, which liquifies a few percent of the upper-midrange/low-treble spittiness and hardness inherent in many recordings. Because silver/oil makes this range less noticeable, the high treble/air becomes relatively more noticeable, but upon closer analysis, the silver/gold has just as much upper end extension and air. So once again, I still think silver/oil is the cap that most likely will have me keep listening to my (non-perfect) music collection instead of tweaking, but if your system is already leaning towards liquidity, silver/gold may be a better choice.
I am probably going to get my hands on a Transcendentsound preamp which is extremely neutral with 12AU7 tubes. So how much are these mundorfs you are talking about 1Uf with 400V or so. Probably the oil ones.Thanks.Ray Bronk
The silver/oils at 1 uF are $54.57/each unfortunately.
