0 Members and 3 Guests are viewing this topic. Read 766312 times.
Compared to silver/oil, Epcos had a bit more richness to voices and even more apparent smoothness in the upper-midrange region, but it conceded some sheer resolution and attack. Silver/oil sounded more like a “modern” film capacitor while Epcos leaned more in the direction of paper-in-oil caps without overt darkness or lack of resolution. I was especially glad to observe Epcos not to possess overly rounded or slow bass like some paper-in-oils can. The Epcos, not surprisingly, sounds VERY much like the Siemens MKV polypropylene in oil capacitor I described earlier. Both sound balanced, if not extraordinarily extended or obviously “airy” up top. Human voices have fluidity, richness, and sparkling liveliness that’s so endearing. If you are a die-hard Teflon or polystyrene fan, you will likely call these poly oil caps a bit slower and not as lit-up, but the fans of the poly oils will call it the opposite.
Hi Jon.....and others. To my knowledge, the Penta Caps are still manufactured by Custom Capacitors Electronics here in New York http://www.customelec.com/. The capacitors I still have here still have the original "Custom Capacitors" logo on them. They were some original beta samples. I could be wrong but maybe they are OEM manufacturing them. My first experience with them was a customer that spoke with the company and had some sent to me (with the Penta name on them) to be installed into a custom tube headphone preamplifier modification. If I remember correctly, they were .22uF and used in the coupling positions. The customer was very happy with the results.
Jon, the Penta Caps are, as noted, manufactured by Custom Electronics in Oneata, NY. The caps I sent you were tin foil plate caps + then best quality teflon ("shaved" according to CustElec).Custom Electronics bought Component Research Corporation goods sold on the latter's bankruptcy. These goods included teflon winding machines etc. which, for their part, augmented Custom Electronics' teflon cap manufacturing facilities. Just some useless information for you.
Hi JonNot sure if you know about this, so I thought I would share it.I was searching for more info on those big Mica's, and I came across this threadhttp://www.diyaudio.com/forums/showthread.php?postid=953144#post953144Google can do a rough translation to the linked page, but the guy basically skinned a Russian Teflon cap. If you keep reading the thread, there is more infomation about skinning Russian caps. Since I have some from Ebay, I am going to have to try this sometime when I get a chance.Randy
Jon,Would you still say the Mundorf silver/gold and the EI output tubes is the best combination in your Almarro A202A MkII?
Yes, I know. I use the A205A MkII as a headphone amp with AKG 701s (the Almarro is for service now, probably in Japan, as long as it takes). I got hold of a bunch of EI EL84's and thought of changing the capacitor to improve the sound even further, so it's a matter of choosing the potentially best cap (for me).
