0 Members and 1 Guest are viewing this topic. Read 27270 times.
Please note, that we are speaking about 2 things, the reproduction of the first arrival of the direct sound and recreating an ambient filed similar to the original. The direct sound is reproduced through XTC and the ambient filed - if it is not recorded independently - created by simulation. With the proper mix of the two, you can get surprisingly "real" reproduction of real acoustic events.Of course with studio recordings ( drums in an anechoic booth, guitars through pickup, vocal close mic-ed and with different added echo in every line ) it is a hit and miss.
OK, but I'm trying to understand why you think the direct sound comes from such a narrow angle? In many live venues it doesn't, including concert halls when you're seated near the front.
Just follow the instructions in the first one for speaker setup: " Ideally, you should sit 2m away from the loudspeakers directly in front of them. The centres of the speakers should then be approximately 35cm apart. If your speakers are very small, try to sit 1m away from them when their centres are 20cm apart. If possible, you should position the loudspeakers in the middle of the room; the fewer reflections you get from the acoustic environment the better."
.....man this thread went quiet.....DGlow - Was there a track for voice outside the right speaker? Did the resulting change of shifting your head replicate itself?
Yes, with legacy stereo material and 2 speakers the sweetspot is small, just like with stereo in a dead room. This is just a technology demo, not a full fledged solution.
Here is some good info on ITD's and ILD's.
And yeah, this thread did get quite after I posted about those links, didn't it?
Quote from: Daygloworange on 18 Jan 2008, 03:10 amAnd yeah, this thread did get quite after I posted about those links, didn't it?Yeah, you set the record straight after that post.
I only had a bit of time to import those files into my digital workstation and run a few quick things to see what might be going on, but to avoid any more conflict here, I'll just keep my findings to myself.Besides, what do I know?
I'd really like to hear from the proponents of transaural, and ambiophonic sound reproduction in this thread ( who have done nothing but bash 2 channel audio, as a feeble attempt at realistic sonic reproduction), who have professed firm understandings of psychoacoustics, to describe, in technical terms, what is happening to the 2 channel signal in the demo, to make it jump from one speaker to the other when you move your head a number of inches off axis?I'd really like to understand better, what it is, that I (apparently) don't understand about the subject.As for me, I'm taking this 2 channel demo into the studio with me, and play around with a couple of things with this recording....Cheers
FWIW I do find you continued insistance that the equilateral setup 'properly' inverts the recording process baffling. Two speakers clearly and irrefutably create 4 acoustic arrivals in the direct field where originally there were only 2.
FWIW I do find you continued insistance that the equilateral setup 'properly' inverts the recording process baffling. Two speakers clearly and irrefutably create 4 acoustic arrivals in the direct field where originally there were only 2. There certainly is lots of room to debate how much this matters and whether any particular xtalk cancellation scheme is better, but to deny that there is a fundamental problem is groundless. I think that particularly in light of Geddes work showing that diffraction and early reflections are a) more perceptually intrusive than originally thought and b) level dependent, there's room to re-evaluate the fundamental assumptions of stereo, due to the similarity of the delayed xtalk signal to a diffraction effect. That said, I use a setup that is pretty much equilateral and quite like it, so saying something is theoretically flawed is not the same as saying it doesn't work acceptably.
Quote from: dwk on 18 Jan 2008, 03:45 pmFWIW I do find you continued insistance that the equilateral setup 'properly' inverts the recording process baffling. Two speakers clearly and irrefutably create 4 acoustic arrivals in the direct field where originally there were only 2. I don't think that's a good way to think about it. You've got to bear in mind that we're not talking about narrow beams here: we're talking about waves, and two waves sources make a pattern of constructive and destructive interference. So I don't think it makes sense to talk about "4 arrivals" - it really doesn't mean much. There's just one value for the air pressure at a given place at a given time, and it's the sum of all the different sound waves impinging on that point at that moment, end of story.
If you really want to hear something very close to what a listener in the venue would hear, you take a dummy head, put it in a chair, put mics in each ear, and record. Then play that back with phones. No speaker system is ever going to beat that - or even get close.
I have neither the desire, nor inclination to debate any of this any further. This thread is full of people making too many declarations of absolutes, which of course is to fend off any possibility of opposing opinion.
