The reason we use an equilateral triangle is so that the speakers are aimed at the proper ear, spaced evenly apart for amplitude and timing, which are critical for proper localization, and that the speakers on axis frequency response is aimed at our ear.
Wow, this is a fascinating topic. Question for the promoters - what recordings and processing equipment are you using for this?
No, the things that are critical for proper localization are to actually have the sounds in the right places and to not have the sound coming from multiple places.
Go back and research pinnae, head transfer functions etc, all the things that the equilateral system fails on. All the artifacts that the triangle creates make the brain do tons more processing and it can never resolve the information because it is incorrect info.
All the artifacts that the triangle creates make the brain do tons more processing and it can never resolve the information because it is incorrect info. This is the definition of listening fatigue and it is the reason I can no longer tolerate the equilateral method.
You can see the list of my gear on the first post. I use it for any recording, even mono. It's not that hard to pull off once you experiment a little, it is has the ultimate tweakibility factor to it, if you like to tweak you'll have tons to tweak.
Isn't a multi speaker arrangement what you are advocating?
Please post a link to a description of how the brain needs to process "tons" more information from a L/R 2 channel setup.You have 2 ears. An (ambient) stereo mic recording is made with 2 mics that are positioned to approximate the way a humans ears capture sound. A 2 channel audio system plays it back with 2 (L/R) transducers aimed at your L/R ears.Where is all the tons of "more information"?Cheers
I have a hard time believing that ambient channels invented by a processor on the fly, where none are present on the recording itself, are going to be more believable than a simple signal path to better equipment.How many good seats are there in this room, by your measure? I'm guessing one.
This is what's known as "changing your tune."
unwanated crosstalk Look at the rays labeled unwanted crosstalk. Where you are suppose to have two rays, you now have four. Not only do you have to process this extra info, the info is incorrect and misleading to your pinnae.
It is incorrectly illustrating (mono, or summed )sound propagation emanating from 2 speakers. It should also show a hemispherical wavefront emanating from the trumpet, not the rays that it is showing.
I'm not sure what your saying, I don't see that this diagram is incorrect.
Why add something into the chain that is not there or can create artifacts? Why add extra waves, beams or whatever? I like to keep it simple, then I don't have to worry about extra things.
You might ask yourself this. Why even bother with all this?
C'mon man, your kidding right? I'm not the one advocating a multi-speaker, multi amp/processor/reverb set up.
Open baffles fascinate me, but don't think I'd ever own them because they don't simulate how sounds are really made. Unless your vocalists have holes in the back of their throats (or a twin singing back to back in perfect assynchronization varying by frequency), the sound they produce only comes out the front.
All sounds in my system are consistent with a natural sound field. Don't be biased toward how many channels/amps or whatever I'm using. Yours is a weak approximation at best. I have done all the research you suggest. This is what it points to. I am open minded, I tried your way it doesn't work for me. Are you open minded enough to try my way or are you so convinced on paper that all the things that I say are wrong, don't matter?
I don't believe either is possible in any realistic sense though having the performers in the room with you is probably closer.
I don't believe your setup is capable of putting the sounds where they are supposed to be. You may be hearing sounds in the places where you would expect them to be, but they are not present as such on your source material and are being artificially fabricated by a digital processor. Some sound isn't the same as proper sound.To say this is the same as a 9.2 recording or whatever is pure folly.I'm not saying you can't enjoy what you have more than a 2 channel setup but to say it's more true to the source is simply impossible.
