0 Members and 1 Guest are viewing this topic. Read 21873 times.
TCG,I musta missed a thread about you getting a SL1200. Is the rega arm going on immediately or will you live with stock for a while and then compare? What are your plans with the Technics TT?have fun playing around and listening!ed
Hi John:I need to point out that there are legions of users here and on the Asylum, who would find the following statement utter blather:Technics....which really is, I think, held back by sub-standard arm assembly (some kind of combination of weak armtube, so-so bearings, poorly designed counterweightThe Technics tonearm, when accompanied by the KAB damping tray and the tonearm rewire leaves little to be desired. I don't usually take issue w/ you but you are on record as being a proponent of this double gimbaled arm as well. The fact that you had a highly modded version of the Rega in your possession already seems to have curiously altered your viewpoint. I don't think its necessary to put down the one, to build up the other. No offense, but the Technics 1200 tonearm especially when damped and rewired gives up very little to other much more costly tonearms.
there's an even better belt if you can find one narrow enough. It has fiberglass threads in it, and is impossible to stretch. Anyway I get my belts these days JoAnne Fabrics for less than a dollar a spool, and there's zero stretch.gary
