0 Members and 1 Guest are viewing this topic. Read 160513 times.
What digital cable and powercord are you using with DAC? We have found that the SteroVox cable works quite well.
I do not have NOS Paradisea DAC but I listened to it before from my friend. So I can not answer and help you to solve your troubleshooting of your DAC. Let the experts do the job.In my opinion, the sound of Paradisea was not impressed (using TDA1545A) even though I have MHDT Reneaissance II (using TDA1543) which I did not like the sound in the first couple weeks. But I still love the analog sound of it after couple modifying tips in the signal path. I have had good impression with TDA1543 DAC chips since they sound more analog than 1545A (to me it is analytical). However, after listening to Promitheus SS DAC (using parallel TDA1545A or each channel has one chip-I am not sure) I have a good impression with TDA1545A. It sounds very very analog especially with vocals with seperation and decays (it is still in a break-in time). In other words, the Promitheus DAC so far is the best DAC I have owned before including NOS, oversampling and upsampling DAC. Thumbs upWe will have a comparison between Paradisea and Promitheus DACs this weekend at my house. So I will let you know.
QuoteWhat digital cable and powercord are you using with DAC? We have found that the SteroVox cable works quite well.rollo,I have tried quite a lot RCA and/or BNC digital cables. It is all depending on your CDP or SB3 and DAC you are using and also the most important factors are your preamp, amp and ICs. I have experimented so far three different RCA digital cables Harmonic Tech Cyberlink Platinum (copper), Audio Consulting (silver) and Homegrown (copper). The best one in my system is HT Platinum and second best is Silver Audio Consulting. I am connecting them between modded SB3 and Promitheus DAC. I will try the Stereovox VX2 and Blue Jeans (BNC)and Zu Ash (RCA).I have used a custom made PC but Nick will send me his own built PC (only for the Promitheus DAC).
Make sure to include my silver plate DIY digital cables in your shootout too. I like to hear how my DIY cable stack up against the high price cables.
Regarding the digital cable, heard that Blue Jeans, Ack! The digital connect and Bolder Cable company are using Belden 1695A to make the digital coaxial cable. From other forum, it is better than Zu Ash (RCA) but with a much cheaper price.
is the DAC also good in playing music such as 1812, Firebird, Carmina Burana, heavy metal kinds of music?
Hi Tan,Glad to hear the good comment from you, is the DAC also good in playing music such as 1812, Firebird, Carmina Burana, heavy metal kinds of music? Regarding the digital cable, heard that Blue Jeans, Ack! The digital connect and Bolder Cable company are using Belden 1695A to make the digital coaxial cable. From other forum, it is better than Zu Ash (RCA) but with a much cheaper price.Cant wait to hear the digital cables review from you.
Have you manage to do the bypass cap. upgrade modification ? its one of the biggest improvement i've heard up to today.
Tanchiro,Did the promi/paradisea comparison happen this past weekend? If so, how'd it go?
F-100, What did you end up using in your modified Paradisea? opa2107 or lm4562? Did you use Paper in oil caps?
... I have experimented so far three different RCA digital cables Harmonic Tech Cyberlink Platinum (copper), Audio Consulting (silver) and Homegrown (copper). The best one in my system is HT Platinum and second best is Silver Audio Consulting. I am connecting them between modded SB3 and Promitheus DAC....
I also tried Mundorf Silver/Oil caps but it was too bright for my taste.
However, it was a 110 ohm silver cable, not copper.
