0 Members and 1 Guest are viewing this topic. Read 48485 times.
Listed below are just a few ways in which ERS paper has been used to control and absorb EMI/RFI. * In general, lining the inside of a component's top cover is a good place to start. If you don't want to open up your piece of equipment, then just lay the sheet on top. * CD/DVD players - attached to the underside of the top, and attached to the bottom. This covers the power supply, and the digital ICs. Digital is probably the most notorious EMI/RFI polluter in a system. * Preamp/ processors - attached in a similar manner as the CD/DVD player. * Home theater processors - Treat similarly to the DVD/CD player. * Electrical outlets - Cut in the same shape as the wall plate and place over the outside of the wall plate. The ERS is placed on the outside of the wall plate because it IS conductive. * Power conditioners - wrapped around power cords, and covering the top, bottom and sides of a power conditioner. A very effective tweak. * Power cords - Wrapping the cord with ERS tape. We have had excellent results doing this. 1" tape works well. Multiple layers work well too. * Power transformers - Keeps stray rfi and magnetic fields from interfering with the audio signal. * Crossovers - Covering the top bottom and sides, as well as wrapping the internal wires. This method needs to be "tuned" to each individual system. You will know when you've added too much ers, when the highs start rolling off, or midrange detail starts disappearing. Be prepared to spend some time on this. * Interconnects - Wrapping the interconnect with ERS tape. This too will require some fine tuning. I use a 1/4" strip wrapped around the very end of the RCA connector's outer shell. You may also try spacing the ERS away from the cable via foam pipe insulation. * Loudspeaker cables - Fine tuning required here as well. Start at the end that connects to the loudspeaker. You may also try spacing the ERS away from the cable via foam pipe insulation. * Video Cables - Component, composite, coaxial, and S-vhs cables all benefit. Wrapping the entire cable provides the most benefit in this caseHow much do I need? Hitting the level of diminishing returns with ERS is difficult, and system dependant. Below are some minimum guidleines for using ERS. * Great results have been achieved by using the ERS tape to wrap power cords and interconnects. If you are odering 1" tape, generally you will need TWICE the length of whatever cord, interconnect, etc. you are trying to wrap. An alternative to wrapping is to lay the ERS length wise down the cord. This may take two, overlapping runs to completely cover the cable, but it is a time saver. ALWAYS do a "test wrap" before removing the adhesive backing! * For lining the top cover of a component, a minimum of two sheets are generally needed. * For an amplifier, be sure to cover the area above and below the power transformer at the minimum. It takes about 1 sheet to do so.
I found the ERS to work not at all helpfully in either my CDP or (former) DAC....it suffocated (kind of overdamped sound) the treble, in particular. It works on power transformers, electrical outlets, conditioners, on IC's (just a little will do), Power Cords....but was a bad tweek inside the 3 digital/switching power supply amps I've owned.
With C-ring made of black beryllium copper and soft, proprietary isolation pads, Herbie's BlackBery Damping Instruments deliver the utmost sonic resolution. Herbie's best damping instrument brings out the "Wow!" factor in your tube gear--for small-signal preamp, input, and driver tubes.
Alan Maher AC Power Enhancer. It is a broadband AC filter that plugs into your AC circuit.$75.Usually has an ad in Audiogon these days.I bought one and it had quite positive results and I already have a dedicated line.Lower noise floor and reduced glare and noise. I ended up getting two more.
