Well I did it,,, Built myself a set of WLM (White Lightning Moonshine) speaker cables.
I won't keep y'all in suspense -with only about 10 hours on them I can easily say: They are REALLY, REALLY good!
Since I needed a set of matching cables for my Emerald Physics CS2, I figured I'd start cheap and take things from there.
I did things a bit differently than the 6 Moons DIY article. #1) I don't use no STANKIN banana plugs - bare wire tinned with silver solder are my "terminations" except for unplated quarter inch push-on connectors attached directly to the HF compression driver. #2) I borrowed an idea from a HD-14 (the orange Home Depot wire) construction post I read and wrapped my two cables for each channel (the CS2's require bi-amping) with Teflon plumber's tape.
I'd been using combinations of wire I had around: Audioquest Type 6, Signal Cable Ultra, and Polk Cobra cable (triple run).
Just as I wanted to use identical top and bottom amplification on the CS2, I wanted to use identical speaker cable to keep everything singing in unison. This is one experiment that's worked out WAY beyond my expectations.
I did have to pay a bit more than I expected for these wires. The Walmart I went to only had the stuff as 20ft. extention cords priced at $7.86 each. Since I need 14ft. runs to each channel I had to buy 4 of them - nearly $32 worth! aa
I used about $5 of Teflon tape and splurged and bought a $4 pack of mutli-colored electrician's tape to pretty things up - total investment about $40 for a custom made, nice looking and GREAT sounding set of speaker cables for my bi-amped system.
With these in the system I feel I am truly hearing what the CS2's are capable of for the first time. I am literally Blown Away by what I am hearing. I see/hear NO reason to look further for speaker wire for this system - not anytime soon anyway. I'll turn my attention to other pursuits and listen to more records.
Doak
