0 Members and 1 Guest are viewing this topic. Read 62180 times.
http://www.tcsounds.com/tc1000.htm
Do you think that a sealed 1801b would be better in this case? What enclosure size do you recommend?
Quote Do you think that a sealed 1801b would be better in this case? What enclosure size do you recommend?It should be theoretically better, but the impact may not be audible. The sealed 1801b cabinet should be about 16 liters. However, if you already have a larger 21 liter cabinet constructed, this will be fine too. Simply stuff the port with a sock. Prefer a good Champion sock, but I am certain that other brands will perform admirably too.Dave
A silly comment.
My hi-fi knowledge is limited
So the 1801b crossover needs to be changed to use a inclined baffle?
