0 Members and 1 Guest are viewing this topic. Read 8385 times.
one word of cautionWith 3 or two way active crossovers (bi/tri-amping) , meaning having a "naked" loudspeaker interacting with an AKSA, you can ask Hugh, when using ribbons, if that can be safely done. If you see how much direct current for a brief moment forces the relative heavy woofer to move half an inch or so in activating and terminating the amp, the fragile o so thin ribbon has no protection at all as it is very naked without its passive filter components.I suppose Hugh will suggest a si ...
