0 Members and 1 Guest are viewing this topic. Read 11217 times.
John,This is the right direction for VMPS to be taking. Great ideas.I'm sure my RM/X's cannot be retrofitted, as you described, without significant pain and suffering, but I know Brian supports going in and shorting out the woofer xover. Is there any possibility that the treble/mid xover can be bypassed in the field? My DEQX arrived this weekend and I'd love to take full advantage of the flexibility of their crossovers. Thx,Ted_B
As one of the guys using a Tact preamp with my RM 40's, I am very happy to hear this John.Please post the details on the woofer upgrade/changes as soon as possible.George
VMPS is interested in offering the tools to allow our users to have the options they need to move in the directions they choose and not have to resort to a significant amount of DIY speaker building unless they enjoy that sort of thing.
Ekovalsky, obviously I have been laboring under a misundestanding. I thought that the TacT and DEQX both worked about the same. You said that the TacT corrects for both speaker and room anomalies (I thought both did) and the DEQX doesn't? Are you saying that the DEQX can correct for one or the other or maybe both somehow? Paul
Before attempting the mid/tweet, can you verify for DEQX/VMPS owners that the DEQX xo can simulate a series first order xo, i.e. a quasi second order? PM me if you need more details. I think it can but I am not 100% sure.
Eric,Is the room correction in the Tact aggresively going after the higher frequencies so as to truly give you a flat target?. In the DEQX you can manually do it, but Auto EQ only addresses 500hz and down, and realistically 300hz and down, the real gremlins in room response. When I try to get rid of the treble troughs the system sounds a bit bright. Realize, though, that I haven't done any speaker correction yet. That's where a lot of that gets fixed...Anyway, was interested in what your RM/X's sound like with gain filters in the higher regions.Ted_B
The TacT technically offers only room correction. However, in calculating the correction filter it uses measured response at the mic position which obviously reflects anomalies from the room and drivers combined. What the TacT cannot do is correct the drivers only. So of the two the DEQX is the more flexible, and it seems to overall have a b ...
