0 Members and 1 Guest are viewing this topic. Read 13449 times.
Eric, I've read your comments with great interest. Would the following statements form an accurate summary?1) Driver correction improves the sound everywhere in the room (both inside the sweet spot and outside the sweet spot).2) Room correction improves the sound inside the sweet spot, but degrades the sound outside the sweet spot.Assuming that I didn't distort or over-simplify your comments, I'm curious about the size of the sweet spot itself when using active correction. Does the activation ...
Very accurate! Glad someone could understand the gibberish that I write With TacT's combined room/speaker correction, the sweet spot is wonderful but small -- about the width of one chair. Moving a little outside that range doesn't degrade things too much but the beautiful floating center image begins to shift and diffuse. Further out, particularly closer to the speakers, distortion of the signal becomes quite evident as the correction filter is applying signal cuts and boosts detrimental to the ...
Very accurate! Glad someone could understand the gibberish that I write icon_eek.gif
With TacT's combined room/speaker correction, the sweet spot is wonderful but small -- about the width of one chair. Moving a little outside that range doesn't degrade things too much but the beautiful floating center image begins to shift and diffuse. Further out, particularly closer to the speakers, distortion of the signal becomes quite evident as the correction filter is applying signal cuts and boosts detrimental to the particular nodes at that position.
As I hinted in an earlier post, the small sweet spot does have its advantages.
Does the TACT allow you to turn these on and off? For instance, correct the speaker when you have a bunch of people in the room, and correct the room when you're listening in stereo?
i wonder if you could do driver correction w/the tact, by placing your speakers outdoors...doug s.
From what I understand from reading this thread, the TACT only performs room correction, while the DEQ/X allows you to perform both speaker and room correction. Is that correct? Why would one choose a TACT over a DEQ/X or vice versa?
IMy question is:Are TACT etc. correction systems appropriate for surround sound also? Nothing to detract from 2 channel systems, but my customer’s world is primarily surround. This is primarily movies, but also SACD and DVD audio.ThanksScott
This system allows the best of both worlds having both "Direct Drive" and Crossover systems in the speaker. It will have 2 times the binding posts.
I will have the pricing "firmed up" shortly and will post them both here and in the "price list" sticky.
Getting back to the original topic:Quote from: John CaslerThis system allows the best of both worlds having both "Direct Drive" and Crossover systems in the speaker. It will have 2 times the binding posts.How do you disconnect the passive crossover when you want to use an active crossover with the direct drive posts?Quote from: John CaslerI will have the pricing "firmed up" shortly and will post them both here and in the "price list" sticky.Any update?-KJ
3) For the "direct drive plus" option, will there be a mechanism to fully disconnect the passive crossover when the "direct drive" binding posts are in use?
Still hoping Brian C. can answer to this one. Assuming there is no manual disconnect and one uses the DD binding posts, wouldn't the signal/current bleed back to the passive crossover?-KJ
I guess I'm a bit confused as to the exact implementation details, specifically:1) Will the "direct drive" option use 4 pairs of binding posts? (Tweeters, mid-range panels, mid-bass woofers, and low bass woofers)2) Will the "direct drive plus" option include 6 pairs of binding posts? (The 4 direct drive pairs described above plus the traditional 2 pair for the bi-ampable passive crossover.)3) For the "direct drive plus" option, will there be a mechanism to fully disconnect the passive crossove ...
