0 Members and 1 Guest are viewing this topic. Read 11080 times.
You should read a few reviews of the Dehavilland Ultravalve as well, one of the best reviewed preamps in that price range (newer versions with remote are available used for less than $2k.) Many, many reviews over the years. It has that tone we love from 6sn7's. I have used used one for several years and have found it highly musical and well balanced if not the last word in treble resolution. Realistically, one shouldn't expect the ultimate in resolution at that price point.
I own Don Sach's DS2 and it is a customized tube pre-amp, meaning it will take 3-4 months to receive from placing order but you will be rewarded with an Outstanding Pre hitting 3-4X about its price point...Wig
I run a BAT VK51se tube pre but used they are going for $3500.
This is alot of money for less than this amount he can order a custom made tubed pre with all the bells and whistles.
I wasn't really recommending the BAT. It uses 8 6H30 tubes and does not have the typical tube preamp sound. It sounds more hybrid but with stunning depth, musicality, detail and powerful tight bass. It sold for $10K new. The AVA preamp and used CJ's, Primaluna are in his budget. I agree the DS's would be the way to go. I priced one up with all the bells and whistles including Duelund caps a little over a year ago but decided to keep my BAT for now since I recapped it and re-tubed it.
Hi allLooking for tube preamp under 2K, no phono but MUST have a remote.Current system:PS Audio Perfectwave TransportSchitt Yaggdrasil DACQuicksilver 300B ampFrankenhorns ( picture top half a Khorn sitting on a bass cabinet)Full loom of Triode Wire LabsBluesound Node 2 streaming TidalPlacette Passive Preamp. I wanted the truth!? Well, maybe I cant handle the truth.I'm listening to alot more Tidal these days. Although the sound is quite good, I feel its a bit "raw" hence the need to add a tube preamp to the chain.I looked into both the Schitt Saga and Freya and owners found no difference in sound when activating the tube stage. Anyone here disagree?Checking the used audio sites I came across a few of interesting prospects. One was the Rogue 99 Super Magnum and the other was Red Wine Audio Isabella Renaissance. Add to the list several VTL models.Open to any and all suggestions and recommendations
