0 Members and 1 Guest are viewing this topic. Read 14911 times.
Do you guys and gals think that Mystsre CA11 for $1095 I linked is bad?
First off, I would like to thank everyone who have contributed to post. All very educational an informative.Secondly, I have made my decision. Drum roll please.Linear Tube Audio Mz2For a "mere" $1545 shipped.I opted for the "NOS" 12sn7s ( can be converted to 6sn7 use with a flick of a switch) and 12au7 input tube as recommended by LTA since I will be using it as a preamp. More volume control usability range as compared to the higher gain 12AT7.Standard power supply and DC cable. Both can be upgraded in the future if so desired.Instead of speaker binding post, they offered to include extra pair RCA outputs.15 day return policy for any reason. No restocking fee. Just pay return shippingOh, and remote of course using motorized Alps Blue Velvet in the remoteLooks pretty cool with plexiglass top. Should have it in a week or so.
Emil if you buy the Russian 6H9C please let me know how is the sound quality?http://www.gstube.com/catalog/?key=6n9s&submit=Find
Congratulations. Let us know how it works in your system. I think you mean the 6h8c. Russian equivalent for 6sn7. Good tube if you can find real/quiet ones. http://www.thetubestore.com/Tubes/6SN7-Tube-Types/Melz-6H8C-6SN7GT Give it time before you start tube rolling. There's plenty of available quality NOS tubes for both positions.
Correct its the 6H8C, but the 6H9C(6SL7) just offer more gain otherwise its the same tube. This preamp dont allow it?
And?
...... Even thou the UV3 and LTA are both 6sn7 based, the LTA didn't have the fullness or lower mid/upper bass bump of the UV3 which some find characteristic of that tube.In other words, no warmth from the LTA and for me a good thing......
.... The recommendation of the MicroZOTL is a good one.....I replaced a quality passive and buffer with a MZ in my horn based system (102db) with a great improvement in transparency and dynamics. It will not sound tubey however, or soften high frequencies if that's a goal.....
