0 Members and 1 Guest are viewing this topic. Read 8978 times.
can anyone here describe the sonic differences between the 6sn7 and the 12sn7?
Zero, it's just heater voltage. My preamp can use either as it has a 6/12V heater switch.
Versatility, would be my guess. More tube options (of the same type), using the same circuit.
I believe LTA introduced the MZ 2 with only 12sn7 output tubes because they are so much less expensive than the 6sn7s of the same branding. Then, many customers asked for a 6 volt switch to utilize tube collections they already had. The current version uses either type. The gain is also variable by using either 12at7 or 12au7 in the input/driver position.
Thanks DaveWhy would you think a manufacturer would offer both as an option?
The 12SN7 is usually less expensive than the 6 volt version. As an added bonus, it allows substitution with a 12SX7 high-performance version.
