What's your favorite preamp tube?
0 Members and 1 Guest are viewing this topic. Read 12406 times.
Yun66
Re: What's your favorite preamp tube?
« Reply #40 on: 24 May 2018, 10:49 pm »
Seems good news, what is the time life from this tube?
I actually don't know. They are very well made. The pair I have has been used in a stage buffer and preamp for about 5 years. They still sound wonderful. I guess their useful life depends on the circuit design.
twitch54
« Reply #41 on: 25 May 2018, 12:22 am »
6sn7? 6922?, 6H30?
I may be in the market for a new preamp. You're thoughts would be helpful
Emil
well.......since my ARC LS28 has 4 6H30Pi's, it's got my vote.
« Reply #42 on: 25 May 2018, 12:34 am »
6sn7? 6922?, 6H30?
Emil
To avoid headache my suggestion are stay away from expensive tubes, ''special'' tubes versions and rare tubes a long with tubes that have few subs. Said that the small tube have more versions I know are 6922:
6N1P Versions:
6N1P 6N2P 6922 6H30 6DJ8 7DJ8 7308 PCC88  ECC88  E88CC  E288CC  6N1 6H23P-EB, Siemens 8223  GA7  CV5358 5670
6N1P have the warmest tone,
6N2P more dinamic than 6N1P,
6922 have the best dynamics,
6DJ8 have the most air and micro-detail with a touch less bass.
7DJ8 again, a powerful tool for voicing your amplifier to your particular tastes.
Double F
« Reply #43 on: 25 May 2018, 06:13 am »
deHavilland Ultraverve, preferably the 3 since it comes with the Kara Chaffee designed 32 step remote relay volume control.  It runs both halves of a 6sn7 so you only need one.  Much easier and cheaper to find than a matching pair. :singing:
Escott1377
« Reply #44 on: 25 May 2018, 07:19 am »
Please try the 300B mesh from EML if you are up for the investment.
Yun66
« Reply #45 on: 25 May 2018, 12:22 pm »
Just curious if channel saparation will be affected when both use the same tube. Modwright LS100 also uses half 6sn7, but one tube per channel.
Double F
« Reply #46 on: 25 May 2018, 03:16 pm »
No affect.  Each 1/2 acts as it's own circuit, however, if the tube is microphonic or noisy both channels will perform poorly.  I test my own tubes for noise and match sections within 300-400 micromhos.
Yun66
« Reply #47 on: 25 May 2018, 03:56 pm »
Good to know! Thanks!
