0 Members and 2 Guests are viewing this topic. Read 2564 times.
$22 shipped for me, on the fence if I want to buy one for a spare iron.What kind of tips does it use, hakko?
I got a lot of soldering done before needing a replacement tip.
I'd skip up to the TS100. It's $50 but it's competitive with $500 irons.
I've owned the unit for several years and still haven't used one of the extra tips I bought.
I use different tips depending on what I'm doing. Large tips work better for cables and connectors where you need more heat. Changing the tip can work better than cranking the heat up when you are soldering something with a large mass. Or sometimes I do both.Small tips for surface mount work, where you need to be precise.
Folsom, do you have a link for the TS100? I couldn’t find it. Thanks, Lester
I hear the stock PSU cord is too stiff.
