0 Members and 1 Guest are viewing this topic. Read 65130 times.
Have been listening the amp for couple weeks, sound very good with the Cornwall and it's quiet.It's a top SS amp does well with the Cornwall.Tested on 4 Ohms speaker, it did not sound right for some reason, only listened for few minutes.Thanks Wushuliu.
I use 14ga PVC-insulated Copper wire from an IEC power cable to connect the power supply to the amp.
Flavo -- I just purchased the 3e-audio 3255. Should take a few weeks to show up and I'm wondering if I'm missing anything in the build or if I should add anything.
I am also interested in this. What are you using for volume control? Are you using a volume pot -- or handling volume externally?
Externally. I currently have a DAC with Vol pot but will be getting a preamp to handle the pot and a different DAC. Unfortunately I'm of no help in knowing what values you need for a Pot. Hopefully one of the experienced folks will be able to help you out.
Are these available in a ready made amp? I love DIY audio and enjoy building, but have almost zero free time these days......well a few hours to do crap like post on forums, but not enough to source component and build an amp I have a lepai 2020A powering my Merlin monitors in my computer monitor setup. Clearly an amp upgrade would help. Lepai is a decent dirt cheap little amp and I'm impressed it can even power these speakers. but it makes me want more. (decided upgraded PS not worth time or money)
Everything is in except a fuse and holder. I didnt think to order one and googling doesn't seem to be helping me. How do I know what size fuse to install for the 3255 with the Meanwell 48V PS? The specs on the Meanwell are --350.4W 48V 7.3A 115Vac or 230VacSo my guess would be a 10A 250V fuse? If that's correct. Do I want a slow blow? Does it matter if it's 5x20 or 6.3x30 and lastly, does anyone have a suggestion on a inline fuse holder? I was thinking it would be easier to find a audio quality one but that's proven difficult as well. Thanks so much.
https://www.ebay.com/itm/FXAUDIO-FX502SPRO-TPA3250-Class-D-Digital-Amplifier-Hi-Fi-Stereo-Audio-Power-Amp-/253284553008
Ordered one of these amps from China (though from a different seller since the one listed in the link sent me a star ornament rather than the amp itself. At least I got refunded). And I have to say that I'm impressed. It replaced a Fleawatt w/ Astron power supply that I'd been using in my system with a ModWright Oppo BD-105 and GR Research Diluceos. More detail and more punch (probably because it is more powerful). But the nice thing about the amp is that you can play with the opamps. I initially put in opa2227's, which improved the separation as well as musically. Now that I've gotten some opa627's, which probably are my favorite opamp musically, this is really turning into a nice amp for about $100. Cheap and cheerful. Can't go wrong.
Thanks for the review. Especially about the opamps. I hadn't thought about whether different opamps might affect sound for these TPA32XX amps (too busy being impressed by what I heard). So this opens up a whole new avenue for exploration.
Given that it's been at least 8 years since I've thought much about opamps, any suggestions about others to try? I'd played around with a bunch in the past and had settled on the opa627's in my Maverick DAC, but I'm sure that there are better things out now.Also, before I forget, if one is going to put opa627's in this amp, they need to be dual SOIC to DIP8. The DIP to DIP ones won't fit.
Can the TPA3251/55 boards be setup for balanced XLR inputs?I have a Class D Audio SDS470 4-channel amplifier. I was wonderingabout using it's case, toroidal transformer and power supply and justswapping in 2 of these boards? ...is that possible? ...practical and safe?Thanks for any replies in advance
