TPA3251/55 High Power Class D Amplifiers
Thomas0322
Re: TPA3251/55 High Power Class D Amplifiers
« Reply #100 on: 14 Jun 2020, 04:30 pm »
I will likely pick up one of the 3255 amps on eBay.  I am covered on the power supply.  Replacing op amps is new to me.  I'd like to try upgrading, but I don't know about that.  I have seen the MUSES02 recommended.  I looked on eBay and within MUSES02 there are a number of choices at very different price points.  Perhaps someone knows of a good article for guidance on this.  I did not find it.  Recommendations for a good replacement op-amp will be appreciated.
chips666
« Reply #101 on: 14 Jun 2020, 06:04 pm »
https://www.diyaudio.com/forums/class-d/276982-tpa3251d2-128.html
Hello,
Look at this thread as from page 128 (bottom) and on ...
several pages about opamp rolling
Enjoy...
xschop
« Reply #102 on: 15 Oct 2023, 07:08 pm »
Has anyone added a 12VDC brushless fan to the Aiyima A07? I'm building a custom case and was curious if adding a DC/DC buck converter internally would introduce noise.
« Reply #103 on: 15 Oct 2023, 07:18 pm »
I would not wish test it myself, I would use a aluminium heatsink.
xschop
« Reply #104 on: 15 Oct 2023, 07:33 pm »
To iterate, I meant I would jumper off the supplied 36V power supply, not from anywhere on the A07 board itself.
I tested the brushless fan with a 9V battery and it flows great with no noise itself.
« Reply #105 on: 15 Oct 2023, 11:06 pm »
I would use a 120V fan connected to the wall, not connected to the amp supply.
xschop
« Reply #106 on: 16 Oct 2023, 03:35 pm »
Ok. I'll err on side of caution and not use the fan for the A07 board as it seems to be cooling just from convection with heat sink fins placed vertically.
« Reply #107 on: 16 Oct 2023, 03:59 pm »
If you live on a cold área not need fan IMO.
zek
« Reply #108 on: 5 Dec 2023, 08:49 pm »
@xschop Have you finished your project?  :popcorn:
xschop
« Reply #109 on: 10 Dec 2023, 08:40 pm »
Case is machined and waiting on CNC lathe again for dial completion. I really like how the whole case acts as a heat sink....
Alain Arseneault
  • Double A
« Reply #110 on: 10 Dec 2023, 09:17 pm »
Hi,
I like people that build their own stuff.
I will follow with interest this project.
Thanks for sharing.
Double A
zek
« Reply #111 on: 10 Dec 2023, 10:56 pm »
@xschop Very well done, congratulations on your enthusiasm.  :thumb:
xschop
« Reply #112 on: 11 Dec 2023, 06:14 pm »
Thanks gents. I have been wanting to design an amp case like this for awhile for aesthetics and function. I really like the sound of this Class D amp and it deserves a custom case.
The design goal is to have all hardware/fasteners hidden with a minimalist appearance and have ability to swap in different amp board later if I want....
I was running it 3/4 volume throttle on the shop speakers all weekend and it never skipped a beat. I could feel the warmer air circulating through lower vent holes by simple convection. Don't even need a fan running in this unit...
xschop
« Reply #113 on: 30 Dec 2023, 06:30 pm »
Fine tuning the dial interface/fitment. A couple thousandths each side is the key to smooth-as-butter operation :)
xschop
« Reply #114 on: 31 Dec 2023, 02:38 pm »
Wanted the dial to mimic my favorite museum watch....Will do final assembly today. Happy New Year everyone....
xschop
« Reply #115 on: 5 Jan 2024, 08:15 pm »
Been running the XS-8TL's with this amp for better part of the last week with my phone DAC and FLAC files.
Barely gets warm running them half volume on the dial.
I took the dial back off and reset it to 6'oclock being zero.
WAF is at 100% too as opposed to the amp and CD player in the living room.
Here's a pic where I removed the fan so you can see direct airflow path to heatsink radiator.
I also added 3/8" height rubber feet
« Last Edit: 6 Jan 2024, 04:07 pm by xschop »
« Reply #116 on: 6 Jan 2024, 12:47 am »
Too big.
S Clark
« Reply #117 on: 6 Jan 2024, 04:17 am »
Sure would be a helluva lot easier to put it in a Folgers coffee can.... get about the same shielding effect.
xschop
« Reply #118 on: 6 Jan 2024, 04:11 pm »
Too big.
 Here are the base dimensions...
I figured out how to upload pics here (I think). It takes up 1/4 the space that my restored Onkyo A8017 amplifier did. It sounds every bit as clear and powerful too.
« Reply #119 on: 6 Jan 2024, 10:03 pm »
Nice, thank you :thumb:
