0 Members and 1 Guest are viewing this topic. Read 11927 times.
I've done some outlet swapping in the past but this, er, is a little problematic. I think you should make clear how risky this is. It's not just a ten minutes and done.I will recommend the Hammond 193l or m choke plugged into wall as a must do tweak instead.As someone who occasionally plays it fast and loose with mains diy, the mapleshade needs serious caution.
I would go with a top shelf dual receptacle from a major industrial manufacture like Hubble [Hubbell].
Too bad there is no image from the outlet back side
I suppose you could hire someone to install it if needed. Even after the added expense it would still be worth it IMO. If I had to go back to my old wall socket after hearing this one I would be miserable.
For the unitiated that would be a very good idea. I just think the installation process for these as outlined by Mapleshade is a little too cavalier, even for a reckless audiophile like me. The lack of a UL should be mentioned and the relevant cautions of insurance liability if something goes horribly wrong, etc. etc. The typical audiophile outlets at least are functionally similar to regular outlets, but these... Anyway, whatever. The overall premise is interesting and probably effective.
Looks safe enough to me. Mapleshade people are not fools. Why would they sell an outlet that would open up liability to them. Just makes no sense. Get a Hubble UL approved if you like but they sound like crap to me.charles
There is a backside photo of the Quad version:
'UL' sticker for this use?* * * * * * * * * * * * * * *I would go with a top shelf dual receptacle from a major industrial manufacture like Hubble.Note that hospital grade might be easier to source these days.
What does "UL" mean? significance for audio?
