0 Members and 2 Guests are viewing this topic. Read 28846 times.
I'd stick with a reputable company like Leviton, Pass & Seymour, or Hubbell. Everything should be done by the books when dealing with electricity.
What does "UL" mean? significance for audio? Also, I didnt see anyone mention use of an isolator or conditioner in the line up, running from the wall receptacle. i would be curious of the SQ difference from the Mapleshade the wall plate for those using additional electrical cleaning units. e.g., I use a RGPC Pole Pig
I am really surprised at falling for total snakeoil on the part of witchdoctor.The outlets pictured are total crap.But if it is a joke, like "April Fools".. no problem.(maybe he is 'testing' what fools will say?)Seriously either witchdoctor got hit in the head with a brick HARD, or is high on LSD.. Then the post might make sense.As it is, he clearly has jumped off the deep end of an empty pool.Mapleshade sells some of the worst POS for AC I have ever seen. But there are fools who will buy them.
Avoid ALL Leviton... They are really cheap junk.Heavy duty Pass & Seymour or Hubbell.. Way to go for stock duplex.
... It transformed the sound to make everything clearer and closer to sounding "live" both in music and movies. ...
A Mapleshade 'Minimalist' outlet did all that?
I just think the installation process for these as outlined by Mapleshade is a little too cavalier, even for a reckless audiophile like me. The lack of a UL should be mentioned and the relevant cautions of insurance liability if something goes horribly wrong, etc. etc. The typical audiophile outlets at least are functionally similar to regular outlets, but these... Anyway, whatever. The overall premise is interesting and probably effective.
Yes, that's why I started this thread. It wasn't subtle, it was much better. FYIhttp://mapleshadestore.com/ownersmanuals/ownersmanual_acoutlet.pdf
Was that for stereo or immersive audio listening?
What does being high on LSD have to do with this? Have you ever tried LSD ?I have and it wouldn't have any effect on this. That's just part of the "Tricky Dick" mentality. And a false cliche.Most of the drugs in your medicine cabinet are far more dangerous and abused much more.
Seriously, the insurance liability part should be an immediate warning flag for everyone. I am also quite positive that putting a wooden plate over a potential source of electrical fire is a recipe for bad juju.
The best way to check and see if the outlet gizmo really did actually make any difference is to put back the stock one. And re-compare.The differences you hear may only be the cleaning effect of taking off and putting back on the AC wire in the wall. plus unplugging everything. (also new contects INSIDE the duplex. (how OLD was the old duplex?)So, even a $2.99 heavy duty duplex replacement might have given you the same improvement.From my own experience I had a "Hospital' outlet, which I thought at first was good. later I noticed my system sounded dull.I took it out and put a Pass & Seymour outlet. The P&S was far better than the other one.So, yes I can note the changes in an outlet.But for the changes you describe, I would think something was seriously wrong with the old outlet/connections.
or b) even better, get rid of the in-wall box (metal or plastic) entirely. If you undertake b), you will need to provide some kind of wood mounting strips for the faceplate screws
2) Our Amish-made Ambrosian maple faceplate eliminates the high dielectric absorption losses of plastic faceplates, as well as the high eddy current losses of metal ones
To paraphrase the simpsons, "if anyone knows about electricity, its the Amish"
