0 Members and 1 Guest are viewing this topic. Read 167267 times.
I continue to have issues with the Gustard not working (not sure if it's a sync issue, or something else?) A quick power cycle resolves it, but I'm wondering if anyone else is seeing the same phenomenon?
Do you mean the Dac is not locking on to the signal and the LCD display says unlocked or something else? I almost never experienced this issue except when my 3rd party USB card started acting up (I only used USB in) then I would get brief (less than 1 second) drop outs in music play, the LCD would quickly change to unlocked. Eventually after a couple months trouble shooting everything else I pulled the third party USB card and the issue went away. At no time was I forced to cycle power on and off to get things fixed.That said a couple things you can try if you are comfortable opening the dac up. Power down the dac wait a bit for caps to discharge. Remove top cover (2mm allen) then make sure the coax cable is securely screwed into the posts on each board and maybe unscrew and then rescrew back in, or if you have a modded unit then check the solder connections. Now look at the white ribbon cables that go from digital to output board and digital to LCD board. Make sure they are seated all the way into the sockets, if you have high quality contact cleaner like Deoxit, or pro gold then you can careful pull the cables out of the socket and clean the contact parts of the cable then very carefully put them back in making sure the silver contact on the ribbon goes fully into the socket. Next you can check the 4 wire connectors that run from behind the volume knob to the LCD board make sure they are secure. If you run USB in I would check to make sure the USB card is fully seated in the PCIe slot. Those are the easy things to check.The other thing are you using any thing between the signal source and the dac. If so remove that and see if the issue goes away. Good luck.
Many thanks to quadman for DIYinHK v3.34 driver! Listening to DSD256 thru the Win10 mini PC NAA & Gustard X20u as I type.
liton2k, send me a PM to discuss.
I am using a HAL MS-2 PC Music Server running WIN 10 Creator using jRiver to kernel stream all sample rates up to 24/192 as well as DSD 128 and 256 feeding an Auralic Vega. No special driver required and kernel streaming sounds substantially better than the latest USB driver from Auralic. If using jRiver 24bit integer is what works in my system.Kernel streaming seems to have far less veiling obscuring the inner details of the music and the reproduced acoustic space is clearer and larger in scope. The manufacturer supplied driver has the most veiling with a progressively less fogginess as you move from direct sound to WASAPI with kernel streaming being the clearest window on the music.Scotty
