0 Members and 1 Guest are viewing this topic. Read 19027 times.
Hold off making any decisions until the speakers have broken in and you've moved into the final room you mentioned. Other than speakers I believe the room is the biggest factor in playback performance. Room size/shape, speaker/listener setup, acoustic isolation, acoustic treatment, and proper bass proprogation are all bigger factors IME than software, sources, amplification, power, or cables. Frankly if you can't develop a decent room, it's honestly better to have a modest in-room system and go for a good headphone system.
very well said JLM!wait a minute ,source doesn't matter? you mean vinyl is IN not OUT for you!?..cheers
FYI - I'll be leaving this place on the 10th so treatments for this place aren't happening.I'm not much of a headphone guy - even though I have about 4 pairs.
Your ruthlessly revealing speakers may end up being the most expensive component you ever bought. Ignorance can indeed be blissful.
And even in your new place, you can try some heavy blankets and/or big pillows and not spend any money on room treatments until you see if it works. When you see that it does, diy absorbers and diffusers are inexpensive and pretty easy to make. Anyway, hope things work out for you, they sure are nice looking speakers.
Maybe too much detail means that the speakers are picking up sounds, such as the musician lightly breathing, which you wouldn't normally hear at the live performance. They could be giving too much weight to extraneous sounds verses the music itself.
All of the reasons for the added harshness at high volumes sometimes don't get around to heat related power compression. I don't think I saw what type of system you used before the new Philharmonics. Perhaps they were able to handle the high sound levels a bit differently compared to your new systems. I have heard many small-woofer two-ways that sound fantastic and do things large multi-way systems can't do... up to a point. Your new speakers seem to use high quality components but the limiting factor- despite he apparent driver quality- is a small woofer trying to make high sound levels. That voice coil can heat up significantly which increases the resistance, which reduces woofer output relative to the tweeter, which can also alter the crossover effect on the response. Therefore, the system balance tilts upward to the treble and the perceived hardness/treble emphasis. Maybe.
Hi,Are you listening to audiophile recordings? If not try some and let us know if there is an improvement. I think your system has components that are well matched but 'rubbish in is rubbish out' with high quality systems.Cheers Rod
Well, there goes the hardware eq option. What media player do you use?
OK - a few more minor changes. Some felt around the tweeters, that softened the harshness ever so slightly. Example, there's a metallic sssss sound on some recordings when someone sings "ch" (as in child). Another set of Straightwire cables cut out another small level of harshness - at the expense of some midrange smoothness and clarity compared to the Soundsilver cablesAlso, I've never played with my JRiver DSP - EQ and room correction. Setting the room correction so at my 8 foot listening distance helped somewhat. If I drop the 12, 14 and 16K eq down more than 3db each that gets rid of the loud volume harshness but obviously at the expense of high frequency accuracy - (dull). So I've kind of compromised by setting them down about 1.5 db each.I am beginning to suspect though that the problem that I am hearing could be all if not mostly the IC cables.
The SurgeX will also remove another layer of harshness...
The biggest difference was with the computer plugged into the SurgeX, it now sounds comparable to the Sony CD player.
